DEV: Move to rubocop-discourse.
diff --git a/.gitignore b/.gitignore
index e8c80a3..82cf817 100644
--- a/.gitignore
+++ b/.gitignore
@@ -8,5 +8,3 @@ test/dummy/tmp/
 test/dummy/.sass-cache
 gems
 .DS_Store
-.rubocop-https---raw-githubusercontent-com-discourse-discourse-master--rubocop-yml
diff --git a/.rubocop-https---raw-githubusercontent-com-discourse-discourse-master--rubocop-yml b/.rubocop-https---raw-githubusercontent-com-discourse-discourse-master--rubocop-yml
new file mode 100644
index 0000000..0cb02e3
--- /dev/null
+++ b/.rubocop-https---raw-githubusercontent-com-discourse-discourse-master--rubocop-yml
@@ -0,0 +1,357 @@
+require:
+  - rubocop-discourse
+  - rubocop-rspec
+AllCops:
+  TargetRubyVersion: 2.6
+  DisabledByDefault: true
+  Exclude:
+    - "db/schema.rb"
+    - "bundle/**/*"
+    - "vendor/**/*"
+    - "node_modules/**/*"
+    - "public/**/*"
+    - "plugins/**/gems/**/*"
+Discourse:
+  Enabled: true
+Discourse/NoChdir:
+  Exclude:
+    - 'spec/**/*' # Specs are run sequentially, so chdir can be used
+    - 'plugins/*/spec/**/*'
+# Prefer &&/|| over and/or.
+Style/AndOr:
+  Enabled: true
+Style/FrozenStringLiteralComment:
+  Enabled: true
+# Align `when` with `case`.
+Layout/CaseIndentation:
+  Enabled: true
+# Align comments with method definitions.
+Layout/CommentIndentation:
+  Enabled: true
+# No extra empty lines.
+Layout/EmptyLines:
+  Enabled: true
+# Use Ruby >= 1.9 syntax for hashes. Prefer { a: :b } over { :a => :b }.
+Style/HashSyntax:
+  Enabled: true
+# Two spaces, no tabs (for indentation).
+Layout/IndentationWidth:
+  Enabled: true
+Layout/SpaceAfterColon:
+  Enabled: true
+Layout/SpaceAfterComma:
+  Enabled: true
+Layout/SpaceAroundEqualsInParameterDefault:
+  Enabled: true
+Layout/SpaceAroundKeyword:
+  Enabled: true
+Layout/SpaceAroundOperators:
+  Enabled: true
+Layout/SpaceBeforeFirstArg:
+  Enabled: true
+# Defining a method with parameters needs parentheses.
+Style/MethodDefParentheses:
+  Enabled: true
+# Use `foo {}` not `foo{}`.
+Layout/SpaceBeforeBlockBraces:
+  Enabled: true
+# Use `foo { bar }` not `foo {bar}`.
+Layout/SpaceInsideBlockBraces:
+  Enabled: true
+# Use `{ a: 1 }` not `{a:1}`.
+Layout/SpaceInsideHashLiteralBraces:
+  Enabled: true
+Layout/SpaceInsideParens:
+  Enabled: true
+# Detect hard tabs, no hard tabs.
+Layout/IndentationStyle:
+  Enabled: true
+# Blank lines should not have any spaces.
+Layout/TrailingEmptyLines:
+  Enabled: true
+# No trailing whitespace.
+Layout/TrailingWhitespace:
+  Enabled: true
+Lint/Debugger:
+  Enabled: true
+Layout/BlockAlignment:
+  Enabled: true
+# Align `end` with the matching keyword or starting expression except for
+# assignments, where it should be aligned with the LHS.
+Layout/EndAlignment:
+  Enabled: true
+  EnforcedStyleAlignWith: variable
+# Use my_method(my_arg) not my_method( my_arg ) or my_method my_arg.
+Lint/RequireParentheses:
+  Enabled: true
+Lint/ShadowingOuterLocalVariable:
+  Enabled: true
+Layout/MultilineMethodCallIndentation:
+  Enabled: true
+  EnforcedStyle: indented
+Layout/HashAlignment:
+  Enabled: true
+Bundler/OrderedGems:
+  Enabled: false
+Style/SingleLineMethods:
+  Enabled: true
+Style/Semicolon:
+  Enabled: true
+  AllowAsExpressionSeparator: true
+Style/RedundantReturn:
+  Enabled: true
+Style/GlobalVars:
+  Enabled: true
+  Severity: warning
+  Exclude:
+    - 'lib/tasks/**/*'
+    - 'script/**/*'
+    - 'spec/**/*.rb'
+# Specs
+RSpec/AnyInstance:
+  Enabled: false # To be decided
+RSpec/AroundBlock:
+  Enabled: true
+RSpec/BeforeAfterAll:
+RSpec/ContextMethod:
+  Enabled: false # TODO
+RSpec/ContextWording:
+RSpec/DescribeClass:
+RSpec/DescribeMethod:
+  Enabled: true
+RSpec/DescribeSymbol:
+RSpec/DescribedClass:
+RSpec/DescribedClassModuleWrapping:
+RSpec/EmptyExampleGroup:
+  Enabled: true
+  Exclude:
+    - 'spec/requests/api/*'
+RSpec/EmptyLineAfterExample:
+RSpec/EmptyLineAfterExampleGroup:
+RSpec/EmptyLineAfterFinalLet:
+RSpec/EmptyLineAfterHook:
+RSpec/EmptyLineAfterSubject:
+RSpec/ExampleLength:
+RSpec/ExampleWithoutDescription:
+  Enabled: true
+RSpec/ExampleWording:
+RSpec/ExpectActual:
+  Enabled: true
+RSpec/ExpectChange:
+RSpec/ExpectInHook:
+RSpec/ExpectOutput:
+  Enabled: true
+RSpec/FilePath:
+RSpec/Focus:
+  Enabled: true
+RSpec/HookArgument:
+RSpec/HooksBeforeExamples:
+RSpec/ImplicitBlockExpectation:
+  Enabled: true
+RSpec/ImplicitExpect:
+RSpec/ImplicitSubject:
+RSpec/InstanceSpy:
+  Enabled: true
+RSpec/InstanceVariable:
+RSpec/InvalidPredicateMatcher:
+  Enabled: true
+RSpec/ItBehavesLike:
+  Enabled: true
+RSpec/IteratedExpectation:
+RSpec/LeadingSubject:
+RSpec/LeakyConstantDeclaration:
+RSpec/LetBeforeExamples:
+RSpec/LetSetup:
+RSpec/MessageChain:
+  Enabled: true
+RSpec/MessageSpies:
+  Enabled: true
+RSpec/MissingExampleGroupArgument:
+  Enabled: true
+RSpec/MultipleDescribes:
+RSpec/MultipleSubjects:
+  Enabled: true
+RSpec/NamedSubject:
+RSpec/NestedGroups:
+RSpec/OverwritingSetup:
+  Enabled: true
+RSpec/ReceiveCounts:
+  Enabled: true
+RSpec/ReceiveNever:
+  Enabled: true
+RSpec/RepeatedDescription:
+RSpec/RepeatedExample:
+RSpec/RepeatedExampleGroupBody:
+RSpec/RepeatedExampleGroupDescription:
+RSpec/ReturnFromStub:
+  Enabled: true
+RSpec/ScatteredSetup:
+RSpec/SharedContext:
+  Enabled: true
+RSpec/SharedExamples:
+  Enabled: true
+RSpec/SingleArgumentMessageChain:
+  Enabled: true
+RSpec/SubjectStub:
+  Enabled: true
+RSpec/UnspecifiedException:
+  Enabled: true
+RSpec/VerifiedDoubles:
+  Enabled: true
+RSpec/VoidExpect:
+  Enabled: true
+RSpec/Yield:
+  Enabled: true
+Capybara/CurrentPathExpectation:
+  Enabled: true
+Capybara/FeatureMethods:
+  Enabled: true
+FactoryBot/AttributeDefinedStatically:
+  Enabled: true
+FactoryBot/CreateList:
+  Enabled: true
+FactoryBot/FactoryClassName:
+  Enabled: true
+Rails/HttpStatus:
+  Enabled: true
diff --git a/.rubocop.yml b/.rubocop.yml
index 0ca7eff..d46296c 100644
--- a/.rubocop.yml
+++ b/.rubocop.yml
@@ -1 +1,2 @@
-inherit_from: https://raw.githubusercontent.com/discourse/discourse/master/.rubocop.yml
+inherit_gem:
+  rubocop-discourse: default.yml
diff --git a/Gemfile b/Gemfile
index df32188..f6bd3b2 100644
--- a/Gemfile
+++ b/Gemfile
@@ -2,4 +2,5 @@
 group :development do
   gem 'translations-manager', git: 'https://github.com/discourse/translations-manager.git'
+  gem 'rubocop-discourse'
index 329af3d..a49fac9 100644
--- a/Gemfile.lock
+++ b/Gemfile.lock
@@ -6,12 +6,35 @@ GIT
 GEM
   specs:
+    ast (2.4.0)
+    jaro_winkler (1.5.4)
+    parallel (1.19.1)
+    parser (2.7.1.2)
+      ast (~> 2.4.0)
+    rainbow (3.0.0)
+    rexml (3.2.4)
+    rubocop (0.82.0)
+      jaro_winkler (~> 1.5.1)
+      parallel (~> 1.10)
+      parser (>= 2.7.0.1)
+      rainbow (>= 2.2.2, < 4.0)
+      rexml
GitHub sha: b0eb952c
