DEV: mutlipart -> multipart spelling fix (#14963)
DEV: mutlipart → multipart spelling fix (#14963)
diff --git a/app/controllers/uploads_controller.rb b/app/controllers/uploads_controller.rb
index 589ccec..c2ea7a1 100644
--- a/app/controllers/uploads_controller.rb
+++ b/app/controllers/uploads_controller.rb
@@ -326,14 +326,14 @@ class UploadsController < ApplicationController
     rescue Aws::S3::Errors::ServiceError => err
       return render_json_error(
-        debug_upload_error(err, "upload.create_mutlipart_failure", additional_detail: err.message),
+        debug_upload_error(err, "upload.create_multipart_failure", additional_detail: err.message),
         status: 422
     rescue BackupRestore::BackupStore::BackupFileExists
       return render_json_error(I18n.t("backup.file_exists"), status: 422)
     rescue BackupRestore::BackupStore::StorageError => err
         status: 422
@@ -422,7 +422,7 @@ class UploadsController < ApplicationController
-        debug_upload_error(err, "upload.abort_mutlipart_failure", additional_detail: "external upload stub id: #{external_upload_stub.id}"),
+        debug_upload_error(err, "upload.abort_multipart_failure", additional_detail: "external upload stub id: #{external_upload_stub.id}"),
         status: 422
@@ -474,7 +474,7 @@ class UploadsController < ApplicationController
-        debug_upload_error(err, "upload.complete_mutlipart_failure", additional_detail: "external upload stub id: #{external_upload_stub.id}"),
+        debug_upload_error(err, "upload.complete_multipart_failure", additional_detail: "external upload stub id: #{external_upload_stub.id}"),
         status: 422
diff --git a/config/locales/server.de.yml b/config/locales/server.de.yml
index d1f2c30..4c72b34 100644
--- a/config/locales/server.de.yml
+++ b/config/locales/server.de.yml
@@ -3611,9 +3611,9 @@ de:
     optimize_failure_message: "Beim Optimieren des hochgeladenen Bildes ist ein Fehler aufgetreten."
     download_failure: "Herunterladen der Datei vom externen Anbieter fehlgeschlagen."
     size_mismatch_failure: "Die Größe der auf S3 hochgeladenen Datei stimmte nicht mit der beabsichtigten Größe des externen Upload-Abschnittes überein. %{additional_detail}"
-    create_mutlipart_failure: "Fehler beim Erstellen eines mehrteiligen Uploads im externen Speicher."
-    abort_mutlipart_failure: "Fehler beim Abbrechen des mehrteiligen Uploads im externen Speicher."
-    complete_mutlipart_failure: "Der mehrteilige Upload im externen Speicher konnte nicht abgeschlossen werden."
+    create_multipart_failure: "Fehler beim Erstellen eines mehrteiligen Uploads im externen Speicher."
+    abort_multipart_failure: "Fehler beim Abbrechen des mehrteiligen Uploads im externen Speicher."
+    complete_multipart_failure: "Der mehrteilige Upload im externen Speicher konnte nicht abgeschlossen werden."
     external_upload_not_found: "Der Upload wurde im externen Speicher nicht gefunden. %{additional_detail}"
     checksum_mismatch_failure: "Die Prüfsumme der hochgeladenen Datei stimmt nicht überein. Der Dateiinhalt könnte sich beim Hochladen geändert haben. Bitte versuche es erneut."
     cannot_promote_failure: "Der Upload kann nicht abgeschlossen werden, er kann bereits abgeschlossen oder zuvor gescheitert sein."
diff --git a/config/locales/server.en.yml b/config/locales/server.en.yml
index 6249277..9cd23f9 100644
--- a/config/locales/server.en.yml
+++ b/config/locales/server.en.yml
@@ -4037,9 +4037,9 @@ en:
     optimize_failure_message: "An error occurred while optimizing the uploaded image."
     download_failure: "Downloading the file from the external provider failed."
     size_mismatch_failure: "The size of the file uploaded to S3 did not match the external upload stub's intended size. %{additional_detail}"
-    create_mutlipart_failure: "Failed to create multipart upload in the external store."
-    abort_mutlipart_failure: "Failed to abort multipart upload in the external store."
-    complete_mutlipart_failure: "Failed to complete multipart upload in the external store."
+    create_multipart_failure: "Failed to create multipart upload in the external store."
+    abort_multipart_failure: "Failed to abort multipart upload in the external store."
+    complete_multipart_failure: "Failed to complete multipart upload in the external store."
     external_upload_not_found: "The upload was not found in the external store. %{additional_detail}"
     checksum_mismatch_failure: "The checksum of the file you uploaded does not match. The file contents may have changed on upload. Please try again."
     cannot_promote_failure: "The upload cannot be completed, it may have already completed or previously failed."
diff --git a/config/locales/server.es.yml b/config/locales/server.es.yml
index 3ea356d..e99c019 100644
--- a/config/locales/server.es.yml
+++ b/config/locales/server.es.yml
@@ -3607,9 +3607,9 @@ es:
     optimize_failure_message: "Ha ocurrido un error al optimizar la imagen subida."
     download_failure: "Ha fallado la descarga del archivo del proveedor externo."
     size_mismatch_failure: "El tamaño del archivo subido a S3 no coincide con el tamaño esperado del stub externo. %{additional_detail}"
-    create_mutlipart_failure: "Fallo al crear una subida en varias partes en el almacenamiento externo."
-    abort_mutlipart_failure: "Fallo al abortar una subida en varias partes en el almacenamiento externo."
-    complete_mutlipart_failure: "Fallo al completar la subida en varias partes en el almacenamiento externo."
+    create_multipart_failure: "Fallo al crear una subida en varias partes en el almacenamiento externo."
+    abort_multipart_failure: "Fallo al abortar una subida en varias partes en el almacenamiento externo."
+    complete_multipart_failure: "Fallo al completar la subida en varias partes en el almacenamiento externo."
     external_upload_not_found: "La carga no se encontró en la tienda externa. %{additional_detail}"
     checksum_mismatch_failure: "La suma de comprobación del archivo que has subido no coincide. Puede que haya cambiado su contenido mientras se subía. Por favor, inténtalo de nuevo."
     cannot_promote_failure: "No se ha podido completar la subida, puede que ya haya terminado o fallado antes."
diff --git a/config/locales/server.he.yml b/config/locales/server.he.yml
index 71e5968..a021f76 100644
--- a/config/locales/server.he.yml
+++ b/config/locales/server.he.yml
@@ -3718,9 +3718,9 @@ he:
     optimize_failure_message: "אירעה שגיאה בעת מיטוב התמונה שהועלתה."
     download_failure: "הורדת הקובץ מהספק החיצוני נכשלה."
     size_mismatch_failure: "גודל הקובץ שנשלח ל־S3 לא תואם לגודל המשלוח המוצהר. %{additional_detail}"
-    create_mutlipart_failure: "יצירת העלאה מרובת חלקים באחסון החיצוני נכשלה."
-    abort_mutlipart_failure: "ביטול העלאה מרובת חלקים באחסון החיצוני נכשל."
-    complete_mutlipart_failure: "השלמת העלאה מרובת חלקים באחסון החיצוני נכשלה."
+    create_multipart_failure: "יצירת העלאה מרובת חלקים באחסון החיצוני נכשלה."
+    abort_multipart_failure: "ביטול העלאה מרובת חלקים באחסון החיצוני נכשל."
+    complete_multipart_failure: "השלמת העלאה מרובת חלקים באחסון החיצוני נכשלה."
     external_upload_not_found: "ההעלאה לא נמצאה באחסון החיצוני. %{additional_detail}"
     checksum_mismatch_failure: "בדיקת התקינות של הקובץ שהעלית שגויה. יכול להיות שתוכן הקובץ השתנה במהלך ההעלאה. נא לנסות שוב."
     cannot_promote_failure: "לא ניתן להשלים את ההעלאה, יתכן שהיא כבר הושלמה או נכשלה בעבר."
diff --git a/config/locales/server.ko.yml b/config/locales/server.ko.yml
index ecda50d..8f0beb7 100644
--- a/config/locales/server.ko.yml
GitHub sha: f52e1258f738dfd54f2660cd74e4aeb44a2a8eb3
This commit appears in #14963 which was approved by tgxworld. It was merged by martin.
