DEV: prettier/eslint
diff --git a/.eslintrc b/.eslintrc
index 8322028..e5dde25 100644
--- a/.eslintrc
+++ b/.eslintrc
@@ -10,67 +10,64 @@
     "ecmaVersion": 7,
     "sourceType": "module"
-  "globals":
-    {"Ember":true,
-    "jQuery":true,
-    "$":true,
-    "RSVP":true,
-    "Discourse":true,
-    "Em":true,
-    "PreloadStore":true,
-    "Handlebars":true,
-    "I18n":true,
-    "bootbox":true,
-    "module":true,
-    "moduleFor":true,
-    "moduleForComponent":true,
-    "Pretender":true,
-    "sandbox":true,
-    "controllerFor":true,
-    "test":true,
-    "ok":true,
-    "not":true,
-    "expect":true,
-    "equal":true,
-    "visit":true,
-    "andThen":true,
-    "click":true,
-    "currentPath":true,
-    "currentRouteName":true,
-    "currentURL":true,
-    "fillIn":true,
-    "keyEvent":true,
-    "triggerEvent":true,
-    "count":true,
-    "exists":true,
-    "visible":true,
-    "invisible":true,
-    "asyncRender":true,
-    "selectDropdown":true,
-    "asyncTestDiscourse":true,
-    "fixture":true,
-    "find":true,
-    "sinon":true,
-    "moment":true,
-    "start":true,
-    "_":true,
-    "alert":true,
-    "containsInstance":true,
-    "deepEqual":true,
-    "notEqual":true,
-    "define":true,
-    "require":true,
-    "requirejs":true,
-    "hasModule":true,
-    "Blob":true,
-    "File":true},
+  "globals": {
+    "Ember": true,
+    "jQuery": true,
+    "$": true,
+    "RSVP": true,
+    "Discourse": true,
+    "PreloadStore": true,
+    "Handlebars": true,
+    "I18n": true,
+    "bootbox": true,
+    "module": true,
+    "moduleFor": true,
+    "moduleForComponent": true,
+    "Pretender": true,
+    "sandbox": true,
+    "controllerFor": true,
+    "test": true,
+    "ok": true,
+    "not": true,
+    "expect": true,
+    "equal": true,
+    "visit": true,
+    "andThen": true,
+    "click": true,
+    "currentPath": true,
+    "currentRouteName": true,
+    "currentURL": true,
+    "fillIn": true,
+    "keyEvent": true,
+    "triggerEvent": true,
+    "count": true,
+    "exists": true,
+    "visible": true,
+    "invisible": true,
+    "asyncRender": true,
+    "selectDropdown": true,
+    "asyncTestDiscourse": true,
+    "fixture": true,
+    "find": true,
+    "sinon": true,
+    "moment": true,
+    "start": true,
+    "_": true,
+    "alert": true,
+    "containsInstance": true,
+    "deepEqual": true,
+    "notEqual": true,
+    "define": true,
+    "require": true,
+    "requirejs": true,
+    "hasModule": true,
+    "Blob": true,
+    "File": true
   "rules": {
     "block-scoped-var": 2,
     "dot-notation": 0,
-    "eqeqeq": [
-      2,
-      "allow-null"
+    "eqeqeq": [2, "allow-null"],
     "guard-for-in": 2,
     "no-bitwise": 2,
     "no-caller": 2,
@@ -96,10 +93,7 @@
     "semi": 2,
     "strict": 0,
     "valid-typeof": 2,
-    "wrap-iife": [
-      2,
-      "inside"
+    "wrap-iife": [2, "inside"]
   "parser": "babel-eslint"
diff --git a/.gitignore b/.gitignore
index ca06557..06257bc 100644
--- a/.gitignore
+++ b/.gitignore
@@ -5,5 +5,5 @@ auto_generated
 Gemfile.lock
 .DS_Store
 *.swp
+node_modules/
 .rubocop-https---raw-githubusercontent-com-discourse-discourse-master--rubocop-yml
diff --git a/package.json b/package.json
new file mode 100644
index 0000000..1348fc3
--- /dev/null
+++ b/package.json
@@ -0,0 +1,12 @@
+  "name": "discourse",
+  "version": "1.0.0",
+  "repository": "git@github.com:discourse/discourse-cakeday.git",
+  "author": "Discourse",
+  "license": "MIT",
+  "devDependencies": {
+    "babel-eslint": "^8.2",
+    "eslint": "^4.19",
+    "prettier": "1.14.3"
diff --git a/yarn.lock b/yarn.lock
index 0000000..36b2054
--- /dev/null
+++ b/yarn.lock
@@ -0,0 +1,1020 @@
+# THIS IS AN AUTOGENERATED FILE. DO NOT EDIT THIS FILE DIRECTLY.
+# yarn lockfile v1
+"@babel/code-frame@7.0.0-beta.44":
+  version "7.0.0-beta.44"
+  resolved "https://registry.yarnpkg.com/@babel/code-frame/-/code-frame-7.0.0-beta.44.tgz#2a02643368de80916162be70865c97774f3adbd9"
+  integrity sha512-cuAuTTIQ9RqcFRJ/Y8PvTh+paepNcaGxwQwjIDRWPXmzzyAeCO4KqS9ikMvq0MCbRk6GlYKwfzStrcP3/jSL8g==
+  dependencies:
+    "@babel/highlight" "7.0.0-beta.44"
+"@babel/generator@7.0.0-beta.44":
+  resolved "https://registry.yarnpkg.com/@babel/generator/-/generator-7.0.0-beta.44.tgz#c7e67b9b5284afcf69b309b50d7d37f3e5033d42"
+  integrity sha512-5xVb7hlhjGcdkKpMXgicAVgx8syK5VJz193k0i/0sLP6DzE6lRrU1K3B/rFefgdo9LPGMAOOOAWW4jycj07ShQ==
+  dependencies:
+    "@babel/types" "7.0.0-beta.44"
+    jsesc "^2.5.1"
+    lodash "^4.2.0"
+    source-map "^0.5.0"
+    trim-right "^1.0.1"
+"@babel/helper-function-name@7.0.0-beta.44":
+  resolved "https://registry.yarnpkg.com/@babel/helper-function-name/-/helper-function-name-7.0.0-beta.44.tgz#e18552aaae2231100a6e485e03854bc3532d44dd"
+  integrity sha512-MHRG2qZMKMFaBavX0LWpfZ2e+hLloT++N7rfM3DYOMUOGCD8cVjqZpwiL8a0bOX3IYcQev1ruciT0gdFFRTxzg==
+  dependencies:
+    "@babel/helper-get-function-arity" "7.0.0-beta.44"
+    "@babel/template" "7.0.0-beta.44"
+"@babel/helper-get-function-arity@7.0.0-beta.44":
+  resolved "https://registry.yarnpkg.com/@babel/helper-get-function-arity/-/helper-get-function-arity-7.0.0-beta.44.tgz#d03ca6dd2b9f7b0b1e6b32c56c72836140db3a15"
+  integrity sha512-w0YjWVwrM2HwP6/H3sEgrSQdkCaxppqFeJtAnB23pRiJB5E/O9Yp7JAAeWBl+gGEgmBFinnTyOv2RN7rcSmMiw==
+  dependencies:
+"@babel/helper-split-export-declaration@7.0.0-beta.44":
+  resolved "https://registry.yarnpkg.com/@babel/helper-split-export-declaration/-/helper-split-export-declaration-7.0.0-beta.44.tgz#c0b351735e0fbcb3822c8ad8db4e583b05ebd9dc"
+  integrity sha512-aQ7QowtkgKKzPGf0j6u77kBMdUFVBKNHw2p/3HX/POt5/oz8ec5cs0GwlgM8Hz7ui5EwJnzyfRmkNF1Nx1N7aA==
+  dependencies:
+"@babel/highlight@7.0.0-beta.44":
+  resolved "https://registry.yarnpkg.com/@babel/highlight/-/highlight-7.0.0-beta.44.tgz#18c94ce543916a80553edcdcf681890b200747d5"
+  integrity sha512-Il19yJvy7vMFm8AVAh6OZzaFoAd0hbkeMZiX3P5HGD+z7dyI7RzndHB0dg6Urh/VAFfHtpOIzDUSxmY6coyZWQ==
+  dependencies:
+    chalk "^2.0.0"
+    esutils "^2.0.2"
+    js-tokens "^3.0.0"
+"@babel/template@7.0.0-beta.44":
+  resolved "https://registry.yarnpkg.com/@babel/template/-/template-7.0.0-beta.44.tgz#f8832f4fdcee5d59bf515e595fc5106c529b394f"
+  integrity sha512-w750Sloq0UNifLx1rUqwfbnC6uSUk0mfwwgGRfdLiaUzfAOiH0tHJE6ILQIUi3KYkjiCDTskoIsnfqZvWLBDng==
+  dependencies:
+    "@babel/code-frame" "7.0.0-beta.44"
+    babylon "7.0.0-beta.44"
+    lodash "^4.2.0"
+"@babel/traverse@7.0.0-beta.44":
+  resolved "https://registry.yarnpkg.com/@babel/traverse/-/traverse-7.0.0-beta.44.tgz#a970a2c45477ad18017e2e465a0606feee0d2966"
+  integrity sha512-UHuDz8ukQkJCDASKHf+oDt3FVUzFd+QYfuBIsiNu/4+/ix6pP/C+uQZJ6K1oEfbCMv/IKWbgDEh7fcsnIE5AtA==
+  dependencies:
+    "@babel/generator" "7.0.0-beta.44"
+    "@babel/helper-function-name" "7.0.0-beta.44"
+    "@babel/helper-split-export-declaration" "7.0.0-beta.44"
+    debug "^3.1.0"
+    globals "^11.1.0"
+    invariant "^2.2.0"
+    lodash "^4.2.0"
+"@babel/types@7.0.0-beta.44":
+  resolved "https://registry.yarnpkg.com/@babel/types/-/types-7.0.0-beta.44.tgz#6b1b164591f77dec0a0342aca995f2d046b3a757"
+  integrity sha512-5eTV4WRmqbaFM3v9gHAIljEQJU4Ssc6fxL61JN+Oe2ga/BwyjzjamwkCVVAQjHGuAX8i0BWo42dshL8eO5KfLQ==
+  dependencies:
+    esutils "^2.0.2"
+    lodash "^4.2.0"
+    to-fast-properties "^2.0.0"
+acorn-jsx@^3.0.0:
+  version "3.0.1"
+  resolved "https://registry.yarnpkg.com/acorn-jsx/-/acorn-jsx-3.0.1.tgz#afdf9488fb1ecefc8348f6fb22f464e32a58b36b"
GitHub sha: a88b4cdf
