DEV: Raise exceptions when jobs fail in test mode
Previously jobs would fail silently in test mode. Now they will raise the exception and cause the relevant test to fail. This identified a few broken tests, which I will fix in a followup commit
diff --git a/lib/discourse.rb b/lib/discourse.rb
index 736dfca..4ef1ebb 100644
--- a/lib/discourse.rb
+++ b/lib/discourse.rb
@@ -54,6 +54,8 @@ module Discourse
       current_db: cm.current_db,
       current_hostname: cm.current_hostname
     }.merge(context))
+    raise ex if Rails.env.test?
   # Expected less matches than what we got in a find
diff --git a/spec/components/discourse_spec.rb b/spec/components/discourse_spec.rb
index 058b61b..a272269 100644
--- a/spec/components/discourse_spec.rb
+++ b/spec/components/discourse_spec.rb
@@ -274,7 +274,10 @@ describe Discourse do
     it "should not fail when called" do
       exception = StandardError.new
-      Discourse.handle_job_exception(exception, nil, nil)
+      expect do
+        Discourse.handle_job_exception(exception, nil, nil)
+      end.to raise_error(StandardError) # Raises in test mode, catch it
       expect(logger.exception).to eq(exception)
       expect(logger.context.keys).to eq([:current_db, :current_hostname])
@@ -282,7 +285,10 @@ describe Discourse do
     it "correctly passes extra context" do
-      Discourse.handle_job_exception(exception, { message: "Doing a test", post_id: 31 }, nil)
+      expect do
+        Discourse.handle_job_exception(exception, { message: "Doing a test", post_id: 31 }, nil)
       expect(logger.context.keys.sort).to eq([:current_db, :current_hostname, :message, :post_id].sort)
GitHub sha: 20cda5d6
:heart:
