DEV: re-enable tests following the timeout fix (#10410)
The 3 skipped tests are failing but not related to timeout
diff --git a/test/javascripts/acceptance/click-track-test.js b/test/javascripts/acceptance/click-track-test.js
index 7e1f78b..d26e96d 100644
--- a/test/javascripts/acceptance/click-track-test.js
+++ b/test/javascripts/acceptance/click-track-test.js
@@ -3,7 +3,7 @@ import { acceptance } from "helpers/qunit-helpers";
 acceptance("Click Track", {});
-QUnit.skip("Do not track mentions", async assert => {
+QUnit.test("Do not track mentions", async assert => {
   pretender.post("/clicks/track", () => assert.ok(false));
   await visit("/t/internationalization-localization/280");
diff --git a/test/javascripts/lib/click-track-test.js b/test/javascripts/lib/click-track-test.js
index 7d5167c..3364e5b 100644
--- a/test/javascripts/lib/click-track-test.js
+++ b/test/javascripts/lib/click-track-test.js
@@ -67,11 +67,11 @@ QUnit.skip("tracks internal URLs", async assert => {
   assert.notOk(track(generateClickEventOn("#same-site")));
-QUnit.skip("does not track elements with no href", async assert => {
+QUnit.test("does not track elements with no href", async assert => {
   assert.ok(track(generateClickEventOn(".a-without-href")));
-QUnit.skip("does not track attachments", async assert => {
+QUnit.test("does not track attachments", async assert => {
   sandbox.stub(DiscourseURL, "origin").returns("http://discuss.domain.com");
@@ -119,39 +119,39 @@ QUnit.skip(
-QUnit.skip("does not track clicks on lightboxes", async assert => {
+QUnit.test("does not track clicks on lightboxes", async assert => {
   assert.notOk(track(generateClickEventOn(".lightbox")));
-QUnit.skip("does not track clicks when forcibly disabled", async assert => {
+QUnit.test("does not track clicks when forcibly disabled", async assert => {
   assert.notOk(track(generateClickEventOn(".no-track-link")));
-QUnit.skip("does not track clicks on back buttons", async assert => {
+QUnit.test("does not track clicks on back buttons", async assert => {
   assert.notOk(track(generateClickEventOn(".back")));
-QUnit.skip("does not track right clicks inside quotes", async assert => {
+QUnit.test("does not track right clicks inside quotes", async assert => {
   const event = generateClickEventOn(".quote a:first-child");
   event.which = 3;
   assert.ok(track(event));
-QUnit.skip("does not track clicks links in quotes", async assert => {
+QUnit.test("does not track clicks links in quotes", async assert => {
   User.currentProp("external_links_in_new_tab", true);
   assert.notOk(track(generateClickEventOn(".quote a:last-child")));
   assert.ok(window.open.calledWith("https://google.com", "_blank"));
-QUnit.skip("does not track clicks on category badges", async assert => {
+QUnit.test("does not track clicks on category badges", async assert => {
   assert.notOk(track(generateClickEventOn(".hashtag")));
-QUnit.skip("does not track clicks on mailto", async assert => {
+QUnit.test("does not track clicks on mailto", async assert => {
   assert.ok(track(generateClickEventOn(".mailto")));
-QUnit.skip("removes the href and put it as a data attribute", async assert => {
+QUnit.test("removes the href and put it as a data attribute", async assert => {
   assert.notOk(track(generateClickEventOn("a")));
@@ -164,7 +164,7 @@ QUnit.skip("removes the href and put it as a data attribute", async assert => {
   assert.ok(window.open.calledWith("http://www.google.com", "_blank"));
-QUnit.skip("restores the href after a while", async assert => {
+QUnit.test("restores the href after a while", async assert => {
   assert.expect(2);
@@ -184,7 +184,7 @@ function badgeClickCount(assert, id, expected) {
   assert.equal(parseInt($badge.html(), 10), expected);
-QUnit.skip("does not update badge clicks on my own link", async assert => {
+QUnit.test("does not update badge clicks on my own link", async assert => {
   sandbox
     .stub(User, "currentProp")
     .withArgs("id")
@@ -192,7 +192,7 @@ QUnit.skip("does not update badge clicks on my own link", async assert => {
   badgeClickCount(assert, "with-badge", 1);
-QUnit.skip("does not update badge clicks in my own post", async assert => {
+QUnit.test("does not update badge clicks in my own post", async assert => {
   sandbox
     .withArgs("id")
@@ -200,14 +200,14 @@ QUnit.skip("does not update badge clicks in my own post", async assert => {
   badgeClickCount(assert, "with-badge-but-not-mine", 1);
-QUnit.skip("updates badge counts correctly", async assert => {
+QUnit.test("updates badge counts correctly", async assert => {
   badgeClickCount(assert, "inside-onebox", 1);
   badgeClickCount(assert, "inside-onebox-forced", 2);
   badgeClickCount(assert, "with-badge", 2);
 function testOpenInANewTab(description, clickEventModifier) {
-  QUnit.skip(description, async assert => {
+  QUnit.test(description, async assert => {
     var clickEvent = generateClickEventOn("a");
     clickEventModifier(clickEvent);
     assert.ok(track(clickEvent));
GitHub sha: 510eaf98
This commit appears in #10410 which was merged by jjaffeux.
