DEV: Refactor custom svg icon caching (#13483)
Previously, we were storing custom svg sprite paths in the cache. This is a problem because sprites in themes get stored as uploads, and the returned paths were files in the temporary download cache which could sometimes be cleaned up, resulting in a broken cache.
I previously tried to fix this by skipping the missing files and clearing the cache, but that didn’t work out well with CDNs. This PR stores the contents of the files in the custom_svg_sprites cache to avoid the problem of missing temp files.
Also, plugin custom icons are only included if the plugin is enabled.
diff --git a/lib/svg_sprite/svg_sprite.rb b/lib/svg_sprite/svg_sprite.rb
index c9eb734..2c0cbe6 100644
--- a/lib/svg_sprite/svg_sprite.rb
+++ b/lib/svg_sprite/svg_sprite.rb
@@ -230,7 +230,12 @@ module SvgSprite
   def self.custom_svg_sprites(theme_id)
     get_set_cache("custom_svg_sprites_#{Theme.transform_ids(theme_id).join(',')}") do
-      custom_sprite_paths = Dir.glob("#{Rails.root}/plugins/*/svg-icons/*.svg")
+      plugin_paths = []
+      Discourse.plugins.map { |plugin| File.dirname(plugin.path) }.each do |path|
+        plugin_paths << "#{path}/svg-icons/*.svg"
+      end
+      custom_sprite_paths = Dir.glob(plugin_paths)
       if theme_id.present?
         ThemeField.where(type_id: ThemeField.types[:theme_upload_var], name: THEME_SPRITE_VAR_NAME, theme_id: Theme.transform_ids(theme_id))
@@ -249,7 +254,14 @@ module SvgSprite
+      custom_sprite_paths.map do |path|
+        if File.exist?(path)
+            filename: "#{File.basename(path, ".svg")}",
+            sprite: File.read(path)
+        end
+      end
@@ -284,13 +296,22 @@ module SvgSprite
   def self.sprite_sources(theme_id)
-    sources = CORE_SVG_SPRITES
+    sprites = []
+    CORE_SVG_SPRITES.each do |path|
+        sprites << {
+      end
+    end
-      sources = sources + custom_svg_sprites(theme_id)
+      sprites = sprites + custom_svg_sprites(theme_id)
-    sources
+    sprites
   def self.core_svgs
@@ -329,20 +350,13 @@ License - https://fontawesome.com/license/free (Icons: CC BY 4.0, Fonts: SIL OFL
-    custom_svg_sprites(theme_id).each do |fname|
-      if !File.exist?(fname)
-        cache.delete("custom_svg_sprites_#{Theme.transform_ids(theme_id).join(',')}")
-        next
-      end
-      svg_file = Nokogiri::XML(File.open(fname)) do |config|
+    custom_svg_sprites(theme_id).each do |item|
+      svg_file = Nokogiri::XML(item[:sprite]) do |config|
         config.options = Nokogiri::XML::ParseOptions::NOBLANKS
-      svg_filename = "#{File.basename(fname, ".svg")}"
       svg_file.css("symbol").each do |sym|
-        icon_id = prepare_symbol(sym, svg_filename)
+        icon_id = prepare_symbol(sym, item[:filename])
         if icons.include? icon_id
           sym.attributes['id'].value = icon_id
@@ -358,14 +372,11 @@ License - https://fontawesome.com/license/free (Icons: CC BY 4.0, Fonts: SIL OFL
   def self.search(searched_icon)
     searched_icon = process(searched_icon.dup)
-    sprite_sources(SiteSetting.default_theme_id).each do |fname|
-      next if !File.exist?(fname)
+    sprite_sources(SiteSetting.default_theme_id).each do |item|
       svg_file.css('symbol').each do |sym|
         if searched_icon == icon_id
@@ -381,14 +392,11 @@ License - https://fontawesome.com/license/free (Icons: CC BY 4.0, Fonts: SIL OFL
   def self.icon_picker_search(keyword)
     results = Set.new
         if keyword.empty? || icon_id.include?(keyword)
           sym.css('title').each(&:remove)
@@ -417,7 +425,7 @@ License - https://fontawesome.com/license/free (Icons: CC BY 4.0, Fonts: SIL OFL
-  def self.prepare_symbol(symbol, svg_filename)
+  def self.prepare_symbol(symbol, svg_filename = nil)
     icon_id = symbol.attr('id')
     case svg_filename
@@ -484,11 +492,8 @@ License - https://fontawesome.com/license/free (Icons: CC BY 4.0, Fonts: SIL OFL
   def self.custom_icons(theme_id)
     # Automatically register icons in sprites added via themes or plugins
     icons = []
         icons << sym.attributes['id'].value if sym.attributes['id'].present?
diff --git a/spec/components/svg_sprite/svg_sprite_spec.rb b/spec/components/svg_sprite/svg_sprite_spec.rb
index 584800e..0ade6bc 100644
--- a/spec/components/svg_sprite/svg_sprite_spec.rb
+++ b/spec/components/svg_sprite/svg_sprite_spec.rb
@@ -156,19 +156,6 @@ describe SvgSprite do
     expect(icons).to include("fly")
-  it 'includes custom icons from a sprite in a theme' do
-    theme = Fabricate(:theme)
-    fname = "custom-theme-icon-sprite.svg"
-    upload = UploadCreator.new(file_from_fixtures(fname), fname, for_theme: true).create_for(-1)
-    theme.set_field(target: :common, name: SvgSprite.theme_sprite_variable_name, upload_id: upload.id, type: :theme_upload_var)
-    theme.save!
-    expect(Upload.where(id: upload.id)).to be_exist
-    expect(SvgSprite.bundle(theme.id)).to match(/my-custom-theme-icon/)
-  end
   context "s3" do
     let(:upload_s3) { Fabricate(:upload_s3) }
@@ -191,8 +178,7 @@ describe SvgSprite do
       theme.save!
       sprite_files = SvgSprite.custom_svg_sprites(theme.id).join("|")
-      expect(sprite_files).to match(/#{upload_s3.sha1}/)
-      expect(sprite_files).not_to match(/amazonaws/)
+      expect(sprite_files).to match(/my-custom-theme-icon/)
       expect(SvgSprite.cache.hash.keys).to include("custom_svg_sprites_#{theme.id}")
@@ -201,9 +187,8 @@ describe SvgSprite do
       File.delete external_copy.try(:path)
-      # when a file is missing, ensure that cache entry is cleared
-      expect(SvgSprite.cache.hash.keys).to_not include("custom_svg_sprites_#{theme.id}")
+      # after a temp file is missing, bundling still works
+      expect(SvgSprite.cache.hash.keys).to include("custom_svg_sprites_#{theme.id}")
@@ -237,4 +222,62 @@ describe SvgSprite do
     group = Fabricate(:group, flair_icon: "far-building")
     expect(SvgSprite.bundle).to match(/far-building/)
+  describe "#custom_svg_sprites" do
+    it 'is empty by default' do
+      expect(SvgSprite.custom_svg_sprites(nil)).to be_empty
+      expect(SvgSprite.bundle).not_to be_empty
+    end
+    context "with a plugin" do
+      let :plugin1 do
+        plugin1 = Plugin::Instance.new
+        plugin1.path = "#{Rails.root}/spec/fixtures/plugins/my_plugin/plugin.rb"
+        plugin1
+      end
+      before do
+        Discourse.plugins << plugin1
+        plugin1.activate!
+      end
+      after do
+        Discourse.plugins.delete plugin1
+      end
+      it "includes custom icons from plugins" do
+        expect(SvgSprite.custom_svg_sprites(nil).size).to eq(1)
+        expect(SvgSprite.bundle).to match(/custom-icon/)
+      end
+    end
+    it 'includes custom icons in a theme' do
+      theme = Fabricate(:theme)
+      fname = "custom-theme-icon-sprite.svg"
+      upload = UploadCreator.new(file_from_fixtures(fname), fname, for_theme: true).create_for(-1)
GitHub sha: fc0da499f83d028d4fab83a8df5cbf78fd171d6c
This commit appears in #13483 which was approved by eviltrout. It was merged by pmusaraj.
