DEV: Refactor tests for notification when liking a post.
Tests were covering the same code path so I’m consolidating it.
diff --git a/spec/models/post_action_spec.rb b/spec/models/post_action_spec.rb
index 1650c87..8cf531d 100644
--- a/spec/models/post_action_spec.rb
+++ b/spec/models/post_action_spec.rb
@@ -275,28 +275,50 @@ describe PostAction do
   describe 'when a user likes something' do
+    before do
+      PostActionNotifier.enable
+    end
-    it 'should generate notifications correctly' do
+    it 'should generate and remove notifications correctly' do
+      expect do
+        PostAction.act(codinghorror, post, PostActionType.types[:like])
+      end.to change { Notification.count }.by(1)
-      PostActionNotifier.enable
+      notification = Notification.last
-      PostAction.act(codinghorror, post, PostActionType.types[:like])
-      expect(Notification.count).to eq(1)
+      expect(notification.user_id).to eq(post.user_id)
+      expect(notification.notification_type).to eq(Notification.types[:liked])
-      mutee = Fabricate(:user)
+      expect do
+        PostAction.remove_act(codinghorror, post, PostActionType.types[:like])
+      end.to change { Notification.count }.by(-1)
-      post = Fabricate(:post)
+      expect(Notification.exists?(id: notification.id)).to eq(false)
+    end
+    it "should not generate a notification if liker has been muted" do
+      mutee = Fabricate(:user)
       MutedUser.create!(user_id: post.user.id, muted_user_id: mutee.id)
-      PostAction.act(mutee, post, PostActionType.types[:like])
+      expect do
+        PostAction.act(mutee, post, PostActionType.types[:like])
+      end.to_not change { Notification.count }
+    end
+    it "should generate a notification if liker is an admin irregardles of \
+      muting" do
       # you can not mute admin, sorry
       MutedUser.create!(user_id: post.user.id, muted_user_id: admin.id)
-      PostAction.act(admin, post, PostActionType.types[:like])
-      expect(Notification.count).to eq(2)
+      expect do
+        PostAction.act(admin, post, PostActionType.types[:like])
     it 'should increase the `like_count` and `like_score` when a user likes something' do
diff --git a/spec/services/post_action_notifier_spec.rb b/spec/services/post_action_notifier_spec.rb
index b52aa8c..85d978f 100644
--- a/spec/services/post_action_notifier_spec.rb
+++ b/spec/services/post_action_notifier_spec.rb
@@ -10,26 +10,6 @@ describe PostActionNotifier do
   let!(:evil_trout) { Fabricate(:evil_trout) }
   let(:post) { Fabricate(:post) }
-  context 'liking' do
-    context 'when liking a post' do
-      it 'creates a notification' do
-        expect {
-          PostAction.act(evil_trout, post, PostActionType.types[:like])
-          # one like (welcome badge deferred)
-        }.to change(Notification, :count).by(1)
-      end
-    end
-    context 'when removing a liked post' do
-      it 'removes a notification' do
-        expect {
-          PostAction.remove_act(evil_trout, post, PostActionType.types[:like])
-        }.to change(Notification, :count).by(-1)
-      end
-    end
-  end
   context 'when editing a post' do
     it 'notifies a user of the revision' do
       expect {
GitHub sha: 78748f15
