DEV: Refactor uppy s3 mulipart mixin to not use self = this (#14960)
We no longer use this pattern, so we can replace with function binding instead.
diff --git a/app/assets/javascripts/discourse/app/mixins/uppy-s3-multipart.js b/app/assets/javascripts/discourse/app/mixins/uppy-s3-multipart.js
index 60ec47a..6253234 100644
--- a/app/assets/javascripts/discourse/app/mixins/uppy-s3-multipart.js
+++ b/app/assets/javascripts/discourse/app/mixins/uppy-s3-multipart.js
@@ -1,13 +1,13 @@
 import Mixin from "@ember/object/mixin";
+import { bind } from "discourse-common/utils/decorators";
 import { Promise } from "rsvp";
 import { ajax } from "discourse/lib/ajax";
 import AwsS3Multipart from "@uppy/aws-s3-multipart";
+const RETRY_DELAYS = [0, 1000, 3000, 5000];
 export default Mixin.create({
   _useS3MultipartUploads() {
     this.set("usingS3MultipartUploads", true);
-    const self = this;
-    const retryDelays = [0, 1000, 3000, 5000];
     this._uppyInstance.use(AwsS3Multipart, {
       // controls how many simultaneous _chunks_ are uploaded, not files,
@@ -18,142 +18,151 @@ export default Mixin.create({
       // chunk size via getChunkSize(file), so we may want to increase
       // the chunk size for larger files
       limit: 10,
-      retryDelays,
+      retryDelays: RETRY_DELAYS,
-      createMultipartUpload(file) {
-        self._uppyInstance.emit("create-multipart", file.id);
+      createMultipartUpload: this._createMultipartUpload,
+      prepareUploadParts: this._prepareUploadParts,
+      completeMultipartUpload: this._completeMultipartUpload,
+      abortMultipartUpload: this._abortMultipartUpload,
-        const data = {
-          file_name: file.name,
-          file_size: file.size,
-          upload_type: file.meta.upload_type,
-          metadata: file.meta,
+      // we will need a listParts function at some point when we want to
+      // resume multipart uploads; this is used by uppy to figure out
+      // what parts are uploaded and which still need to be
-        // the sha1 checksum is set by the UppyChecksum plugin, except
-        // for in cases where the browser does not support the required
-        // crypto mechanisms or an error occurs. it is an additional layer
-        // of security, and not required.
-        if (file.meta.sha1_checksum) {
-          data.metadata = { "sha1-checksum": file.meta.sha1_checksum };
+  @bind
+  _createMultipartUpload(file) {
+    this._uppyInstance.emit("create-multipart", file.id);
-        return ajax("/uploads/create-multipart.json", {
-          type: "POST",
-          data,
-          // uppy is inconsistent, an error here fires the upload-error event
-        }).then((responseData) => {
-          self._uppyInstance.emit("create-multipart-success", file.id);
+    const data = {
+      file_name: file.name,
+      file_size: file.size,
+      upload_type: file.meta.upload_type,
+      metadata: file.meta,
-          file.meta.unique_identifier = responseData.unique_identifier;
-          return {
-            uploadId: responseData.external_upload_identifier,
-            key: responseData.key,
+    // the sha1 checksum is set by the UppyChecksum plugin, except
+    // for in cases where the browser does not support the required
+    // crypto mechanisms or an error occurs. it is an additional layer
+    // of security, and not required.
+    if (file.meta.sha1_checksum) {
+      data.metadata = { "sha1-checksum": file.meta.sha1_checksum };
-      prepareUploadParts(file, partData) {
-        if (file.preparePartsRetryAttempts === undefined) {
-          file.preparePartsRetryAttempts = 0;
-        return ajax("/uploads/batch-presign-multipart-parts.json", {
-          type: "POST",
-          data: {
-            part_numbers: partData.partNumbers,
-            unique_identifier: file.meta.unique_identifier,
-          .then((data) => {
-            if (file.preparePartsRetryAttempts) {
-              delete file.preparePartsRetryAttempts;
-              self._consoleDebug(
-                `[uppy] Retrying batch fetch for ${file.id} was successful, continuing.`
-            return { presignedUrls: data.presigned_urls };
-          .catch((err) => {
-            const status = err.jqXHR.status;
+    return ajax("/uploads/create-multipart.json", {
+      type: "POST",
+      data,
+      // uppy is inconsistent, an error here fires the upload-error event
+    }).then((responseData) => {
+      this._uppyInstance.emit("create-multipart-success", file.id);
-            // it is kind of ugly to have to track the retry attempts for
-            // the file based on the retry delays, but uppy's `retryable`
-            // function expects the rejected Promise data to be structured
-            // _just so_, and provides no interface for us to tell how many
-            // times the upload has been retried (which it tracks internally)
-            // if we exceed the attempts then there is no way that uppy will
-            // retry the upload once again, so in that case the alert can
-            // be safely shown to the user that their upload has failed.
-            if (file.preparePartsRetryAttempts < retryDelays.length) {
-              file.preparePartsRetryAttempts += 1;
-              const attemptsLeft =
-                retryDelays.length - file.preparePartsRetryAttempts + 1;
-                `[uppy] Fetching a batch of upload part URLs for ${file.id} failed with status ${status}, retrying ${attemptsLeft} more times...`
-              return Promise.reject({ source: { status } });
-            } else {
-                `[uppy] Fetching a batch of upload part URLs for ${file.id} failed too many times, throwing error.`
-              // uppy is inconsistent, an error here does not fire the upload-error event
-              self._handleUploadError(file, err);
+      file.meta.unique_identifier = responseData.unique_identifier;
+      return {
+        uploadId: responseData.external_upload_identifier,
+        key: responseData.key,
-      completeMultipartUpload(file, data) {
-        self._uppyInstance.emit("complete-multipart", file.id);
-        const parts = data.parts.map((part) => {
-          return { part_number: part.PartNumber, etag: part.ETag };
-        return ajax("/uploads/complete-multipart.json", {
-          type: "POST",
-          contentType: "application/json",
-          data: JSON.stringify({
-            parts,
-            pasted: file.meta.pasted,
-            for_private_message: file.meta.for_private_message,
-          self._uppyInstance.emit("complete-multipart-success", file.id);
-          return responseData;
+  @bind
+  _prepareUploadParts(file, partData) {
+    if (file.preparePartsRetryAttempts === undefined) {
+      file.preparePartsRetryAttempts = 0;
+    return ajax("/uploads/batch-presign-multipart-parts.json", {
+      type: "POST",
+      data: {
+        part_numbers: partData.partNumbers,
+        unique_identifier: file.meta.unique_identifier,
-      abortMultipartUpload(file, { key, uploadId }) {
-        // if the user cancels the upload before the key and uploadId
-        // are stored from the createMultipartUpload response then they
-        // will not be set, and we don't have to abort the upload because
-        // it will not exist yet
-        if (!key || !uploadId) {
-          return;
+      .then((data) => {
+        if (file.preparePartsRetryAttempts) {
+          delete file.preparePartsRetryAttempts;
+          this._consoleDebug(
GitHub sha: 7e39910de617441a1643099583b75d0720c6f479
This commit appears in #14960 which was approved by CvX. It was merged by martin.
