DEV: refactoring admin-logs-screened-ip-addresses (#6932)
diff --git a/app/assets/javascripts/admin/controllers/admin-logs-screened-ip-addresses.js.es6 b/app/assets/javascripts/admin/controllers/admin-logs-screened-ip-addresses.js.es6
index a5eb32a..595a628 100644
--- a/app/assets/javascripts/admin/controllers/admin-logs-screened-ip-addresses.js.es6
+++ b/app/assets/javascripts/admin/controllers/admin-logs-screened-ip-addresses.js.es6
@@ -11,8 +11,7 @@ export default Ember.Controller.extend({
   show: debounce(function() {
     this.set("loading", true);
     ScreenedIpAddress.findAll(this.get("filter")).then(result => {
-      this.set("model", result);
-      this.set("loading", false);
+      this.setProperties({ model: result, loading: false });
   }, 250).observes("filter"),
@@ -35,8 +34,9 @@ export default Ember.Controller.extend({
     cancel(record) {
-      if (this.get("savedIpAddress") && record.get("editing")) {
-        record.set("ip_address", this.get("savedIpAddress"));
+      const savedIpAddress = this.get("savedIpAddress");
+      if (savedIpAddress && record.get("editing")) {
+        record.set("ip_address", savedIpAddress);
       record.set("editing", false);
@@ -46,9 +46,7 @@ export default Ember.Controller.extend({
       record
         .save()
-        .then(() => {
-          this.set("savedIpAddress", null);
+        .then(() => this.set("savedIpAddress", null))
         .catch(e => {
           if (e.jqXHR.responseJSON && e.jqXHR.responseJSON.errors) {
             bootbox.alert(
@@ -84,7 +82,7 @@ export default Ember.Controller.extend({
               .catch(e => {
                 bootbox.alert(
                   I18n.t("generic_error_with_reason", {
-                    error: "http: " + e.status + " - " + e.body
+                    error: `http: ${e.status} - ${e.body}`
@@ -98,25 +96,24 @@ export default Ember.Controller.extend({
     rollUp() {
-      const self = this;
       return bootbox.confirm(
         I18n.t("admin.logs.screened_ips.roll_up_confirm"),
         I18n.t("no_value"),
         I18n.t("yes_value"),
-        function(confirmed) {
+        confirmed => {
           if (confirmed) {
-            self.set("loading", true);
-            return ScreenedIpAddress.rollUp().then(function(results) {
+            this.set("loading", true);
+            return ScreenedIpAddress.rollUp().then(results => {
               if (results && results.subnets) {
                 if (results.subnets.length > 0) {
-                  self.send("show");
+                  this.send("show");
                   bootbox.alert(
                     I18n.t("admin.logs.screened_ips.rolled_up_some_subnets", {
                       subnets: results.subnets.join(", ")
                 } else {
-                  self.set("loading", false);
+                  this.set("loading", false);
                   bootbox.alert(
                     I18n.t("admin.logs.screened_ips.rolled_up_no_subnet")
diff --git a/app/assets/javascripts/admin/templates/logs/screened-ip-addresses.hbs b/app/assets/javascripts/admin/templates/logs/screened-ip-addresses.hbs
index 4e1def3..c5819da 100644
--- a/app/assets/javascripts/admin/templates/logs/screened-ip-addresses.hbs
+++ b/app/assets/javascripts/admin/templates/logs/screened-ip-addresses.hbs
@@ -1,26 +1,38 @@
-<p>{{i18n 'admin.logs.screened_ips.description'}}</p>
+<p>{{i18n "admin.logs.screened_ips.description"}}</p>
 <div class="screened-ip-controls">
   <div class="filter-screened-ip-address">
-    {{text-field value=filter class="ip-address-input" placeholderKey="admin.logs.screened_ips.form.filter" autocorrect="off" autocapitalize="off"}}
-    {{d-button class="btn-default" action=(action "rollUp") title="admin.logs.screened_ips.roll_up.title" label="admin.logs.screened_ips.roll_up.text"}}
-    {{d-button class="btn-default" action=(action "exportScreenedIpList") icon="download" title="admin.export_csv.button_title.screened_ip" label="admin.export_csv.button_text"}}
+    {{text-field
+      value=filter
+      class="ip-address-input"
+      placeholderKey="admin.logs.screened_ips.form.filter"
+      autocorrect="off"
+      autocapitalize="off"}}
+    {{d-button
+      class="btn-default"
+      action=(action "rollUp")
+      title="admin.logs.screened_ips.roll_up.title"
+      label="admin.logs.screened_ips.roll_up.text"}}
+    {{d-button
+      action=(action "exportScreenedIpList")
+      icon="download"
+      title="admin.export_csv.button_title.screened_ip"
+      label="admin.export_csv.button_text"}}
   </div>
-    {{screened-ip-address-form action=(action "recordAdded")}}
-</div>
+  {{screened-ip-address-form action=(action "recordAdded")}}
+</div>
 {{#conditional-loading-spinner condition=loading}}
   {{#if model.length}}
-    <table class='admin-logs-table screened-ip-addresses grid'>
+    <table class="admin-logs-table screened-ip-addresses grid">
       <thead class="heading-container">
-        <th class="col heading first ip_address">{{i18n 'admin.logs.ip_address'}}</th>
-        <th class="col heading action">{{i18n 'admin.logs.action'}}</th>
-        <th class="col heading match_count">{{i18n 'admin.logs.match_count'}}</th>
-        <th class="col heading created_at">{{i18n 'admin.logs.created_at'}}</th>
-        <th class="col heading last_match_at">{{i18n 'admin.logs.last_match_at'}}</th>
+        <th class="col heading first ip_address">{{i18n "admin.logs.ip_address"}}</th>
+        <th class="col heading action">{{i18n "admin.logs.action"}}</th>
+        <th class="col heading match_count">{{i18n "admin.logs.match_count"}}</th>
+        <th class="col heading created_at">{{i18n "admin.logs.created_at"}}</th>
+        <th class="col heading last_match_at">{{i18n "admin.logs.last_match_at"}}</th>
         <th class="col heading actions"></th>
       </thead>
       <tbody>
@@ -47,34 +59,64 @@
             {{/if}}
             {{item.actionName}}
           </td>
-          <td class="col match_count"><div class="label">{{i18n 'admin.logs.match_count'}}</div> {{item.match_count}}</td>
-          <td class="col created_at"><div class="label">{{i18n 'admin.logs.created_at'}}</div> {{age-with-tooltip item.created_at}}</td>
+          <td class="col match_count">
+            <div class="label">{{i18n "admin.logs.match_count"}}</div>
+            {{item.match_count}}
+          </td>
+          <td class="col created_at">
+            <div class="label">{{i18n "admin.logs.created_at"}}</div>
+            {{age-with-tooltip item.created_at}}
+          </td>
           <td class="col last_match_at">
             {{#if item.last_match_at}}
-               <div class="label">{{i18n 'admin.logs.last_match_at'}} {{age-with-tooltip item.last_match_at}}</div>
+                {{i18n "admin.logs.last_match_at"}}
+                {{age-with-tooltip item.last_match_at}}
+              </div>
             {{/if}}
           </td>
           <td class="col actions">
             {{#unless item.editing}}
-              {{d-button class="btn-default" action=(action "destroy") actionParam=item icon="far-trash-alt" class="btn-danger"}}
-              {{d-button class="btn-default"action=(action "edit") actionParam=item icon="pencil-alt"}}
+              {{d-button
+                action=(action "destroy")
+                actionParam=item
+                icon="far-trash-alt"
+                class="btn-danger"}}
+              {{d-button
+                action=(action "edit")
+                actionParam=item
+                icon="pencil-alt"}}
               {{#if item.isBlocked}}
GitHub sha: bd314231
