DEV: refactoring api-keys (#6931)
diff --git a/app/assets/javascripts/admin/controllers/admin-api-keys.js.es6 b/app/assets/javascripts/admin/controllers/admin-api-keys.js.es6
index 69a1c32..1ec203f 100644
--- a/app/assets/javascripts/admin/controllers/admin-api-keys.js.es6
+++ b/app/assets/javascripts/admin/controllers/admin-api-keys.js.es6
@@ -1,6 +1,12 @@
 import ApiKey from "admin/models/api-key";
+import { default as computed } from "ember-addons/ember-computed-decorators";
 export default Ember.Controller.extend({
+  @computed("model.[]")
+  hasMasterKey(model) {
+    return !!model.findBy("user", null);
   actions: {
     generateMasterKey() {
       ApiKey.generateMasterKey().then(key => this.get("model").pushObject(key));
@@ -31,10 +37,5 @@ export default Ember.Controller.extend({
-  // Has a master key already been generated?
-  hasMasterKey: function() {
-    return !!this.get("model").findBy("user", null);
-  }.property("model.[]")
diff --git a/app/assets/javascripts/admin/models/api-key.js.es6 b/app/assets/javascripts/admin/models/api-key.js.es6
index 5636250..4b0eb65 100644
--- a/app/assets/javascripts/admin/models/api-key.js.es6
+++ b/app/assets/javascripts/admin/models/api-key.js.es6
@@ -1,32 +1,22 @@
 import AdminUser from "admin/models/admin-user";
 import { ajax } from "discourse/lib/ajax";
-const ApiKey = Discourse.Model.extend({
-    Regenerates the api key
+const KEY_ENDPOINT = "/admin/api/key";
+const KEYS_ENDPOINT = "/admin/api/keys";
-    @method regenerate
-    @returns {Promise} a promise that resolves to the key
-  regenerate: function() {
-    var self = this;
-    return ajax("/admin/api/key", {
+const ApiKey = Discourse.Model.extend({
+  regenerate() {
+    return ajax(KEY_ENDPOINT, {
       type: "PUT",
       data: { id: this.get("id") }
-    }).then(function(result) {
-      self.set("key", result.api_key.key);
-      return self;
+    }).then(result => {
+      this.set("key", result.api_key.key);
+      return this;
-    Revokes the current key
-    @method revoke
-    @returns {Promise} a promise that resolves when the key has been revoked
-  revoke: function() {
+  revoke() {
       type: "DELETE",
@@ -34,45 +24,24 @@ const ApiKey = Discourse.Model.extend({
 ApiKey.reopenClass({
-    Creates an API key instance with internal user object
-    @method create
-    @param {...} var_args the properties to initialize this with
-    @returns {ApiKey} the ApiKey instance
   create() {
-    var result = this._super.apply(this, arguments);
+    const result = this._super.apply(this, arguments);
     if (result.user) {
       result.user = AdminUser.create(result.user);
     return result;
-    Finds a list of API keys
-    @method find
-    @returns {Promise} a promise that resolves to the array of `ApiKey` instances
-  find: function() {
-    return ajax("/admin/api/keys").then(function(keys) {
-      return keys.map(function(key) {
-        return ApiKey.create(key);
+  find() {
+    return ajax(KEYS_ENDPOINT).then(keys =>
+      keys.map(key => ApiKey.create(key))
-    Generates a master api key and returns it.
-    @method generateMasterKey
-    @returns {Promise} a promise that resolves to a master `ApiKey`
-  generateMasterKey: function() {
-    return ajax("/admin/api/key", { type: "POST" }).then(function(result) {
-      return ApiKey.create(result.api_key);
+  generateMasterKey() {
+    return ajax(KEY_ENDPOINT, { type: "POST" }).then(result =>
+      ApiKey.create(result.api_key)
diff --git a/app/assets/javascripts/admin/templates/api-keys.hbs b/app/assets/javascripts/admin/templates/api-keys.hbs
index 1b85311..d631e41 100644
--- a/app/assets/javascripts/admin/templates/api-keys.hbs
+++ b/app/assets/javascripts/admin/templates/api-keys.hbs
@@ -1,35 +1,47 @@
 {{#if model}}
-  <table class='api-keys grid'>
+  <table class="api-keys grid">
   <thead>
-    <th>{{i18n 'admin.api.key'}}</th>
-    <th>{{i18n 'admin.api.user'}}</th>
+    <th>{{i18n "admin.api.key"}}</th>
+    <th>{{i18n "admin.api.user"}}</th>
     <th>&nbsp;</th>
   </thead>
   <tbody>
     {{#each model as |k|}}
       <tr>
-        <td class='key'>{{k.key}}</td>
+        <td class="key">{{k.key}}</td>
         <td class="key-user">
           {{#if k.user}}
-            {{#link-to 'adminUser' k.user}}
+            {{#link-to "adminUser" k.user}}
               {{avatar k.user imageSize="small"}}
             {{/link-to}}
           {{else}}
-            {{i18n 'admin.api.all_users'}}
+            {{i18n "admin.api.all_users"}}
           {{/if}}
         </td>
         <td class="key-controls">
-          {{d-button class="btn-default" action=(action "regenerateKey") actionParam=k icon="undo" label='admin.api.regenerate'}}
-          {{d-button class="btn-default" action=(action "revokeKey") actionParam=k icon="times" label='admin.api.revoke'}}
+          {{d-button
+            class="btn-default"
+            action=(action "regenerateKey")
+            actionParam=k icon="undo"
+            label="admin.api.regenerate"}}
+          {{d-button
+            action=(action "revokeKey")
+            actionParam=k
+            icon="times"
+            label="admin.api.revoke"}}
         </td>
       </tr>
     {{/each}}
   </tbody>
   </table>
 {{else}}
-  <p>{{i18n 'admin.api.none'}}</p>
+  <p>{{i18n "admin.api.none"}}</p>
 {{/if}}
 {{#unless hasMasterKey}}
-<button class='btn btn-icon no-text btn-primary' {{action "generateMasterKey"}}>{{d-icon "key"}}</button>
+  {{d-button
+    class="btn-primary"
+    action=(action "generateMasterKey")
+    icon="key"}}
 {{/unless}}
GitHub sha: 60974932
