DEV: Remove buffered rendering from i18n count
This is another refactoring in the multi-step process to remove all uses of our custom Render Buffer.
Previous commit: 80f4b9e2279856eb34349636a50a3cc3967ffaf3 in this series.
This commit affects the display of translated counts that is used in multiple places like showing how many posts are selected using the select posts feature on a topic. It is just a refactor and does not change any functionality.
diff --git a/app/assets/javascripts/discourse/components/count-i18n.js.es6 b/app/assets/javascripts/discourse/components/count-i18n.js.es6
index 9bdb715dc5..d0fd9bdccb 100644
--- a/app/assets/javascripts/discourse/components/count-i18n.js.es6
+++ b/app/assets/javascripts/discourse/components/count-i18n.js.es6
@@ -1,17 +1,15 @@
 import Component from "@ember/component";
-import { bufferedRender } from "discourse-common/lib/buffered-render";
-export default Component.extend(
-  bufferedRender({
-    tagName: "span",
-    rerenderTriggers: ["count", "suffix"],
+export default Component.extend({
+  tagName: "span",
+  rerenderTriggers: ["count", "suffix"],
+  i18nCount: null,
-    buildBuffer(buffer) {
-      buffer.push(
-        I18n.t(this.key + (this.suffix || ""), {
-          count: this.count
+  didReceiveAttrs() {
+    this._super(...arguments);
+    this.set(
+      "i18nCount",
+      I18n.t(this.key + (this.suffix || ""), { count: this.count }).htmlSafe()
diff --git a/app/assets/javascripts/discourse/templates/components/count-i18n.hbs b/app/assets/javascripts/discourse/templates/components/count-i18n.hbs
new file mode 100644
index 0000000000..f7a5927a07
--- /dev/null
+++ b/app/assets/javascripts/discourse/templates/components/count-i18n.hbs
@@ -0,0 +1 @@
+{{i18nCount}}
GitHub sha: 2290ec9e
DEV: Remove buffered rendering from input tips
