DEV: Remove deprecated methods (#14885)
diff --git a/lib/flag_query.rb b/lib/flag_query.rb
index 5c6c0bc..beb69d7 100644
--- a/lib/flag_query.rb
+++ b/lib/flag_query.rb
@@ -1,9 +1,6 @@
 # frozen_string_literal: true
-require 'ostruct'
 module FlagQuery
   def self.plugin_post_custom_fields
     @plugin_post_custom_fields ||= {}
@@ -12,212 +9,4 @@ module FlagQuery
   def self.register_plugin_post_custom_field(field, plugin)
     plugin_post_custom_fields[field] = plugin
-  def self.flagged_posts_report(current_user, opts = nil)
-    Discourse.deprecate("FlagQuery is deprecated, use the Reviewable API instead.", since: "2.3.0beta5", drop_from: "2.4")
-    opts ||= {}
-    offset = opts[:offset] || 0
-    per_page = opts[:per_page] || 25
-    reviewables = ReviewableFlaggedPost.default_visible.viewable_by(current_user, order: 'created_at DESC')
-    reviewables = reviewables.where(topic_id: opts[:topic_id]) if opts[:topic_id]
-    reviewables = reviewables.where(target_created_by_id: opts[:user_id]) if opts[:user_id]
-    reviewables = reviewables.limit(per_page).offset(offset)
-    if opts[:filter] == 'old'
-      reviewables = reviewables.where("status <> ?", Reviewable.statuses[:pending])
-    else
-      reviewables = reviewables.pending
-    end
-    total_rows = reviewables.count
-    post_ids = reviewables.map(&:target_id).uniq
-    posts = DB.query(<<~SQL, post_ids: post_ids)
-      SELECT p.id,
-             p.cooked as excerpt,
-             p.raw,
-             p.user_id,
-             p.topic_id,
-             p.post_number,
-             p.reply_count,
-             p.hidden,
-             p.deleted_at,
-             p.user_deleted,
-             NULL as post_action_ids,
-             (SELECT created_at FROM post_revisions WHERE post_id = p.id AND user_id = p.user_id ORDER BY created_at DESC LIMIT 1) AS last_revised_at,
-             (SELECT COUNT(*) FROM post_actions WHERE (disagreed_at IS NOT NULL OR agreed_at IS NOT NULL OR deferred_at IS NOT NULL) AND post_id = p.id)::int AS previous_flags_count
-        FROM posts p
-       WHERE p.id in (:post_ids)
-    SQL
-    post_lookup = {}
-    user_ids = Set.new
-    topic_ids = Set.new
-    posts.each do |p|
-      user_ids << p.user_id
-      topic_ids << p.topic_id
-      p.excerpt = Post.excerpt(p.excerpt)
-      post_lookup[p.id] = p
-    end
-    all_post_actions = []
-    reviewables.each do |r|
-      post = post_lookup[r.target_id]
-      post.post_action_ids ||= []
-      r.reviewable_scores.order('created_at desc').each do |rs|
-        action = {
-          id: rs.id,
-          post_id: post.id,
-          user_id: rs.user_id,
-          post_action_type_id: rs.reviewable_score_type,
-          created_at: rs.created_at,
-          disposed_by_id: rs.reviewed_by_id,
-          disposed_at: rs.reviewed_at,
-          disposition: ReviewableScore.statuses[rs.status],
-          targets_topic: r.payload['targets_topic'],
-          staff_took_action: rs.took_action?
-        action[:name_key] = PostActionType.types.key(rs.reviewable_score_type)
-        if rs.meta_topic.present?
-          meta_posts = rs.meta_topic.ordered_posts
-          conversation = {}
-          if response = meta_posts[0]
-            action[:related_post_id] = response.id
-            conversation[:response] = {
-              excerpt: excerpt(response.cooked),
-              user_id: response.user_id
-            user_ids << response.user_id
-            if reply = meta_posts[1]
-              conversation[:reply] = {
-                excerpt: excerpt(reply.cooked),
-                user_id: reply.user_id
-              user_ids << reply.user_id
-              conversation[:has_more] = rs.meta_topic.posts_count > 2
-            end
-          end
-          action.merge!(permalink: rs.meta_topic.relative_url, conversation: conversation)
-        end
-        post.post_action_ids << action[:id]
-        all_post_actions << action
-        user_ids << action[:user_id]
-        user_ids << rs.reviewed_by_id if rs.reviewed_by_id
-      end
-    end
-    post_custom_field_names = []
-    plugin_post_custom_fields.each do |field, plugin|
-      post_custom_field_names << field if plugin.enabled?
-    end
-    post_custom_fields = Post.custom_fields_for_ids(post_ids, post_custom_field_names)
-    # maintain order
-    posts = post_ids.map { |id| post_lookup[id] }
-    # TODO: add serializer so we can skip this
-    posts.map! do |post|
-      result = post.to_h
-      if cfs = post_custom_fields[post.id]
-        result[:custom_fields] = cfs
-      end
-      result
-    end
-    guardian = Guardian.new(current_user)
-    users = User.includes(:user_stat).where(id: user_ids.to_a).to_a
-    User.preload_custom_fields(users, User.allowed_user_custom_fields(guardian))
-      posts,
-      Topic.with_deleted.where(id: topic_ids.to_a).to_a,
-      users,
-      all_post_actions,
-      total_rows
-  end
-  def self.flagged_post_actions(opts = nil)
-    Discourse.deprecate("FlagQuery is deprecated, please use the Reviewable API instead.", since: "2.3.0beta5", drop_from: "2.4")
-    opts ||= {}
-    scores = ReviewableScore.includes(:reviewable).where('reviewables.type' => 'ReviewableFlaggedPost')
-    scores = scores.where('reviewables.topic_id' => opts[:topic_id]) if opts[:topic_id]
-    scores = scores.where('reviewables.target_created_by_id' => opts[:user_id]) if opts[:user_id]
-    if opts[:filter] == 'without_custom'
-      return scores.where(reviewable_score_type: PostActionType.flag_types_without_custom.values)
-    end
-    if opts[:filter] == "old"
-      scores = scores.where('reviewables.status <> ?', Reviewable.statuses[:pending])
-    else
-      scores = scores.where('reviewables.status' => Reviewable.statuses[:pending])
-    end
-    scores
-  end
-  def self.flagged_topics
-    Discourse.deprecate("FlagQuery has been deprecated. Please use the Reviewable API instead.", since: "2.3.0beta5", drop_from: "2.4")
-    params = {
-      pending: Reviewable.statuses[:pending],
-      min_score: Reviewable.min_score_for_priority
-    results = DB.query(<<~SQL, params)
-      SELECT rs.reviewable_score_type,
-        p.id AS post_id,
-        r.topic_id,
-        rs.created_at,
-        p.user_id
-      FROM reviewables AS r
-      INNER JOIN reviewable_scores AS rs ON rs.reviewable_id = r.id
-      INNER JOIN posts AS p ON p.id = r.target_id
-      WHERE r.type = 'ReviewableFlaggedPost'
-        AND r.status = :pending
-        AND r.score >= :min_score
-      ORDER BY rs.created_at DESC
-    SQL
-    ft_by_id = {}
-    results.each do |r|
-      ft = ft_by_id[r.topic_id] ||= OpenStruct.new(
-        topic_id: r.topic_id,
-        flag_counts: {},
-        user_ids: Set.new,
-        last_flag_at: r.created_at,
-      ft.flag_counts[r.reviewable_score_type] ||= 0
-      ft.flag_counts[r.reviewable_score_type] += 1
-      ft.user_ids << r.user_id
-      user_ids << r.user_id
-    end
-    all_topics = Topic.where(id: ft_by_id.keys).to_a
-    all_topics.each { |t| ft_by_id[t.id].topic = t }
-    Topic.preload_custom_fields(all_topics, TopicList.preloaded_custom_fields)
-      flagged_topics: ft_by_id.values,
-      users: User.where(id: user_ids)
-  end
GitHub sha: 388f45c5709a92d55ae18a785ff5d525e8a9f974
This commit appears in #14885 which was approved by eviltrout. It was merged by danielwaterworth.
