DEV: Remove `Discourse` constants from focus mixin.
DEV: Remove Discourse constants from focus mixin.
Also removes the mixin which was only used in app/app
diff --git a/app/assets/javascripts/discourse-common/addon/mixins/focus-event.js b/app/assets/javascripts/discourse-common/addon/mixins/focus-event.js
deleted file mode 100644
index 0688c90..0000000
--- a/app/assets/javascripts/discourse-common/addon/mixins/focus-event.js
+++ /dev/null
@@ -1,45 +0,0 @@
-import { bind } from "@ember/runloop";
-import { getOwner } from "discourse-common/lib/get-owner";
-import Mixin from "@ember/object/mixin";
-export default Mixin.create({
-  ready() {
-    this._super(...arguments);
-    this._onChangeHandler = bind(this, this._onChange);
-    // Default to true
-    Discourse.set("hasFocus", true);
-    document.addEventListener("visibilitychange", this._onChangeHandler);
-    document.addEventListener("resume", this._onChangeHandler);
-    document.addEventListener("freeze", this._onChangeHandler);
-  reset() {
-    document.removeEventListener("visibilitychange", this._onChangeHandler);
-    document.removeEventListener("resume", this._onChangeHandler);
-    document.removeEventListener("freeze", this._onChangeHandler);
-    this._onChangeHandler = null;
-  _onChange() {
-    const container = getOwner(this);
-    const appEvents = container.lookup("service:app-events");
-    if (document.visibilityState === "hidden") {
-      if (Discourse.hasFocus) {
-        Discourse.set("hasFocus", false);
-        appEvents.trigger("discourse:focus-changed", false);
-    } else {
-      if (!Discourse.hasFocus) {
-        appEvents.trigger("discourse:focus-changed", true);
diff --git a/app/assets/javascripts/discourse/app/app.js b/app/assets/javascripts/discourse/app/app.js
index 23ea0b1..b484afc 100644
--- a/app/assets/javascripts/discourse/app/app.js
+++ b/app/assets/javascripts/discourse/app/app.js
@@ -2,15 +2,18 @@
 import Application from "@ember/application";
 import { computed } from "@ember/object";
 import { buildResolver } from "discourse-common/resolver";
+import { bind } from "@ember/runloop";
 import discourseComputed, { observes } from "discourse-common/utils/decorators";
-import FocusEvent from "discourse-common/mixins/focus-event";
 const _pluginCallbacks = [];
-const Discourse = Application.extend(FocusEvent, {
+const Discourse = Application.extend({
   rootElement: "#main",
   _docTitle: document.title,
   __widget_helpers: {},
+  hasFocus: null,
+  _boundFocusChange: null,
   customEvents: {
     paste: "paste"
@@ -18,6 +21,24 @@ const Discourse = Application.extend(FocusEvent, {
   reset() {
     Mousetrap.reset();
+    document.removeEventListener("visibilitychange", this._boundFocusChange);
+    document.removeEventListener("resume", this._boundFocusChange);
+    document.removeEventListener("freeze", this._boundFocusChange);
+    this._boundFocusChange = null;
+  ready() {
+    this._super(...arguments);
+    this._boundFocusChange = bind(this, this._focusChanged);
+    // Default to true
+    this.set("hasFocus", true);
+    document.addEventListener("visibilitychange", this._boundFocusChange);
+    document.addEventListener("resume", this._boundFocusChange);
+    document.addEventListener("freeze", this._boundFocusChange);
   getURL(url) {
@@ -178,7 +199,19 @@ const Discourse = Application.extend(FocusEvent, {
       return this.currentAssetVersion;
+  _focusChanged() {
+    if (document.visibilityState === "hidden") {
+      if (this.hasFocus) {
+        this.set("hasFocus", false);
+        this.appEvents.trigger("discourse:focus-changed", false);
+    } else if (!this.hasFocus) {
+      this.appEvents.trigger("discourse:focus-changed", true);
 export default Discourse;
diff --git a/app/assets/javascripts/discourse/app/pre-initializers/inject-discourse-objects.js b/app/assets/javascripts/discourse/app/pre-initializers/inject-discourse-objects.js
index 8140c5f..30d1fb4 100644
--- a/app/assets/javascripts/discourse/app/pre-initializers/inject-discourse-objects.js
+++ b/app/assets/javascripts/discourse/app/pre-initializers/inject-discourse-objects.js
@@ -20,6 +20,7 @@ export default {
     // backwards compatibility: remove when plugins have updated
     app.register("store:main", Store);
+    app.appEvents = container.lookup("service:app-events");
     if (!app.hasRegistration("service:store")) {
       app.register("service:store", Store);
GitHub sha: 7c2d3275
