DEV: Remove duplicate test (#12989)
I think this test was duplicated on accident. We test for the exact thing a few lines up.
diff --git a/spec/lib/upload_creator_spec.rb b/spec/lib/upload_creator_spec.rb
index 67e67da..69f2450 100644
--- a/spec/lib/upload_creator_spec.rb
+++ b/spec/lib/upload_creator_spec.rb
@@ -478,14 +478,6 @@ RSpec.describe UploadCreator do
-        context "if the upload is for a PM" do
-          let(:opts) { { for_private_message: true } }
-          it "sets the upload to secure and sets the original_sha1" do
-            expect(result.secure).to eq(true)
-            expect(result.original_sha1).not_to eq(nil)
-          end
-        end
         context "if SiteSetting.login_required" do
           before do
             SiteSetting.login_required = true
GitHub sha: 23de5e95
This commit appears in #12989 which was approved by romanrizzi. It was merged by blake.
