DEV: remove fragile spec
The failover spec is very fragile and tests specific implementation vs actual behavior
We rely on a different script during the build process to test failover operates correctly
diff --git a/spec/components/active_record/connection_adapters/postgresql_fallback_adapter_spec.rb b/spec/components/active_record/connection_adapters/postgresql_fallback_adapter_spec.rb
deleted file mode 100644
index 8a53e37..0000000
--- a/spec/components/active_record/connection_adapters/postgresql_fallback_adapter_spec.rb
+++ /dev/null
@@ -1,171 +0,0 @@
-# frozen_string_literal: true
-require 'rails_helper'
-describe ActiveRecord::ConnectionHandling do
-  let(:replica_host) { "1.1.1.1" }
-  let(:replica_port) { 6432 }
-  let(:config) do
-    ActiveRecord::Base.connection_config.merge(
-      adapter: "postgresql_fallback",
-      replica_host: replica_host,
-      replica_port: replica_port
-  end
-  let(:multisite_db) { "database_2" }
-  let(:multisite_config) do
-      host: 'localhost1',
-      port: 5432,
-  end
-  let(:postgresql_fallback_handler) { PostgreSQLFallbackHandler.instance }
-  before do
-    @threads = Thread.list
-    postgresql_fallback_handler.initialized = true
-  end
-  after do
-    Sidekiq.unpause!
-    (Thread.list - @threads).each(&:kill)
-    postgresql_fallback_handler.setup!
-    ActiveRecord::Base.unstub(:postgresql_connection)
-    ActiveRecord::Base.clear_all_connections!
-    ActiveRecord::Base.establish_connection
-    Discourse.redis.flushall
-  end
-  describe "#postgresql_fallback_connection" do
-    it 'should return a PostgreSQL adapter' do
-      connection = ActiveRecord::Base.postgresql_fallback_connection(config)
-      expect(connection)
-        .to be_an_instance_of(ActiveRecord::ConnectionAdapters::PostgreSQLAdapter)
-    end
-    context 'when master server is down' do
-      let(:replica_connection) { mock('replica_connection') }
-      it 'should failover to a replica server' do
-        RailsMultisite::ConnectionManagement
-          .stubs(:all_dbs)
-          .returns(['default', multisite_db])
-        postgresql_fallback_handler.expects(:verify_master).at_least(3)
-        [config, multisite_config].each do |configuration|
-          ActiveRecord::Base.expects(:postgresql_connection)
-            .with(configuration)
-            .raises(PG::ConnectionBad)
-          ActiveRecord::Base.expects(:verify_replica).with(replica_connection)
-          ActiveRecord::Base.expects(:postgresql_connection).with(
-            configuration.dup.merge(host: replica_host, port: replica_port)
-          ).returns(replica_connection)
-        end
-        expect(postgresql_fallback_handler.master_down?).to eq(nil)
-        message = MessageBus.track_publish(PostgreSQLFallbackHandler::DATABASE_DOWN_CHANNEL) do
-          expect { ActiveRecord::Base.postgresql_fallback_connection(config) }
-            .to raise_error(PG::ConnectionBad)
-        end.first
-        expect(message.data[:db]).to eq('default')
-        expect(message.data[:pid]).to eq(Process.pid)
-          .to change { Discourse.readonly_mode? }.from(false).to(true)
-        expect(postgresql_fallback_handler.master_down?).to eq(true)
-        expect(Sidekiq.paused?).to eq(true)
-        with_multisite_db(multisite_db) do
-          begin
-              expect { ActiveRecord::Base.postgresql_fallback_connection(multisite_config) }
-            end.first
-            expect(message.data[:db]).to eq(multisite_db)
-            expect do
-              ActiveRecord::Base.postgresql_fallback_connection(multisite_config)
-            end.to change { Discourse.readonly_mode? }.from(false).to(true)
-          ensure
-            postgresql_fallback_handler.master_up(multisite_db)
-          end
-        end
-        postgresql_fallback_handler.initiate_fallback_to_master
-        expect(Discourse.readonly_mode?).to eq(false)
-        expect(Sidekiq.paused?).to eq(false)
-        expect(ActiveRecord::Base.connection_pool.connections.count).to eq(0)
-        expect(ActiveRecord::Base.connection)
-      end
-    end
-    context 'when both master and replica server is down' do
-      it 'should raise the right error' do
-          .with(config)
-          .once
-          .with(
-            config.dup.merge(host: replica_host, port: replica_port)
-          .once
-        postgresql_fallback_handler.expects(:verify_master).twice
-        2.times do
-        end
-      end
-    end
-  end
-  describe '.verify_replica' do
-    describe 'when database is not in recovery' do
-        expect do
-          ActiveRecord::Base.send(:verify_replica, ActiveRecord::Base.connection)
-        end.to raise_error(RuntimeError, "Replica database server is not in recovery mode.")
-      end
-    end
-  end
-  def with_multisite_db(dbname)
-    begin
-      RailsMultisite::ConnectionManagement.expects(:current_db).returns(dbname).at_least_once
-      yield
-    ensure
-      RailsMultisite::ConnectionManagement.unstub(:current_db)
-    end
-  end
-end
GitHub sha: f8c18ac8
