DEV: Remove `fsl` cookie from specs (#13657)
DEV: Remove fsl cookie from specs (#13657)
This cookie has not been used for a number of years, and has no effect. This commit removes it from the specs. (diff is almost entirely whitespace)
diff --git a/spec/requests/omniauth_callbacks_controller_spec.rb b/spec/requests/omniauth_callbacks_controller_spec.rb
index bd74215..8f99c8e 100644
--- a/spec/requests/omniauth_callbacks_controller_spec.rb
+++ b/spec/requests/omniauth_callbacks_controller_spec.rb
@@ -600,108 +600,98 @@ RSpec.describe Users::OmniauthCallbacksController do
-      context 'with full screen login' do
-        before do
-          cookies['fsl'] = true
-        end
-        it "doesn't attempt redirect to external origin" do
-          post "/auth/google_oauth2?origin=https://example.com/external"
-          get "/auth/google_oauth2/callback"
-          expect(response.status).to eq 302
-          expect(response.location).to eq "http://test.localhost/"
+      it "doesn't attempt redirect to external origin" do
+        post "/auth/google_oauth2?origin=https://example.com/external"
+        get "/auth/google_oauth2/callback"
-          cookie_data = JSON.parse(response.cookies['authentication_data'])
-          expect(cookie_data["destination_url"]).to eq('/')
-        end
+        expect(response.status).to eq 302
+        expect(response.location).to eq "http://test.localhost/"
-        it "redirects to internal origin" do
-          post "/auth/google_oauth2?origin=http://test.localhost/t/123"
+        cookie_data = JSON.parse(response.cookies['authentication_data'])
+        expect(cookie_data["destination_url"]).to eq('/')
+      end
-          expect(response.location).to eq "http://test.localhost/t/123"
+      it "redirects to internal origin" do
+        post "/auth/google_oauth2?origin=http://test.localhost/t/123"
-          expect(cookie_data["destination_url"]).to eq('/t/123')
-        end
+        expect(response.location).to eq "http://test.localhost/t/123"
-        it "redirects to internal origin on subfolder" do
-          set_subfolder "/subpath"
+        expect(cookie_data["destination_url"]).to eq('/t/123')
+      end
-          post "/auth/google_oauth2?origin=http://test.localhost/subpath/t/123"
+      it "redirects to internal origin on subfolder" do
+        set_subfolder "/subpath"
-          expect(response.location).to eq "http://test.localhost/subpath/t/123"
+        post "/auth/google_oauth2?origin=http://test.localhost/subpath/t/123"
-          expect(cookie_data["destination_url"]).to eq('/subpath/t/123')
-        end
+        expect(response.location).to eq "http://test.localhost/subpath/t/123"
-        it "never redirects to /auth/ origin" do
-          post "/auth/google_oauth2?origin=http://test.localhost/auth/google_oauth2"
+        expect(cookie_data["destination_url"]).to eq('/subpath/t/123')
+      end
+      it "never redirects to /auth/ origin" do
+        post "/auth/google_oauth2?origin=http://test.localhost/auth/google_oauth2"
-        end
-        it "never redirects to /auth/ origin on subfolder" do
+      end
-          post "/auth/google_oauth2?origin=http://test.localhost/subpath/auth/google_oauth2"
+      it "never redirects to /auth/ origin on subfolder" do
-          expect(response.location).to eq "http://test.localhost/subpath"
+        post "/auth/google_oauth2?origin=http://test.localhost/subpath/auth/google_oauth2"
-          expect(cookie_data["destination_url"]).to eq('/subpath')
-        end
+        expect(response.location).to eq "http://test.localhost/subpath"
-        it "redirects to relative origin" do
-          post "/auth/google_oauth2?origin=/t/123"
+        expect(cookie_data["destination_url"]).to eq('/subpath')
+      end
+      it "redirects to relative origin" do
+        post "/auth/google_oauth2?origin=/t/123"
-        end
-        it "redirects with query" do
-          post "/auth/google_oauth2?origin=/t/123?foo=bar"
+      end
-          expect(response.location).to eq "http://test.localhost/t/123?foo=bar"
+      it "redirects with query" do
+        post "/auth/google_oauth2?origin=/t/123?foo=bar"
-          expect(cookie_data["destination_url"]).to eq('/t/123?foo=bar')
-        end
+        expect(response.location).to eq "http://test.localhost/t/123?foo=bar"
-        it "removes authentication_data cookie on logout" do
+        expect(cookie_data["destination_url"]).to eq('/t/123?foo=bar')
+      end
-          provider = log_in_user(Fabricate(:user))
+      it "removes authentication_data cookie on logout" do
-          expect(cookies['authentication_data']).to be
+        provider = log_in_user(Fabricate(:user))
-          log_out_user(provider)
+        expect(cookies['authentication_data']).to be
-          expect(cookies['authentication_data']).to be_nil
-        end
+        log_out_user(provider)
-        after do
-          cookies.delete('fsl')
-        end
+        expect(cookies['authentication_data']).to be_nil
GitHub sha: a1e5a6bbe07ffdb25b76a7ae031bf2b4c8fac2e3
This commit appears in #13657 which was approved by CvX. It was merged by davidtaylorhq.
