DEV: Remove Job stub.
diff --git a/spec/components/cooked_post_processor_spec.rb b/spec/components/cooked_post_processor_spec.rb
index ebca1f0..938c9c8 100644
--- a/spec/components/cooked_post_processor_spec.rb
+++ b/spec/components/cooked_post_processor_spec.rb
@@ -1228,9 +1228,10 @@ describe CookedPostProcessor do
     it "works only on new posts" do
+      SiteSetting.queue_jobs = false
       hidden = Fabricate(:post, topic: topic, hidden: true, raw: "this is the second post after")
       small_action = Fabricate(:post, topic: topic, post_type: Post.types[:small_action])
-      Jobs.stubs(:enqueue) { |job, args| CookedPostProcessor.new(reply).post_process(new_post: args[:new_post]) if job == :process_post }
       reply = PostCreator.create!(topic.user, topic_id: topic.id, raw: raw)
GitHub sha: b9b5527c
