DEV: Remove migration that is no longer required.
Avoid creating the index twice.
Follow-up to 628319aad385eb001f900c2c1909448b101b75a2
diff --git a/db/migrate/20200813090811_create_partial_index_on_post_search_data.rb b/db/migrate/20200813090811_create_partial_index_on_post_search_data.rb
deleted file mode 100644
index 4189f36..0000000
--- a/db/migrate/20200813090811_create_partial_index_on_post_search_data.rb
+++ /dev/null
@@ -1,17 +0,0 @@
-# frozen_string_literal: true
-class CreatePartialIndexOnPostSearchData < ActiveRecord::Migration[6.0]
-  disable_ddl_transaction!
-  def up
-    execute <<~SQL
-    CREATE INDEX CONCURRENTLY idx_regular_post_search_data ON post_search_data USING GIN(search_data) WHERE NOT private_message
-    SQL
-  end
-  def down
-    execute <<~SQL
-    DROP INDEX IF EXISTS idx_regular_post_search_data;
-    SQL
-  end
-end
GitHub sha: 0967ce47
