DEV: Remove obsolete commented out tests
Commented out in 2016 in ff74bd7e28a13014dd09228445bf0a9938066518
diff --git a/test/javascripts/acceptance/search-full-test.js b/test/javascripts/acceptance/search-full-test.js
index d869af6..06af593 100644
--- a/test/javascripts/acceptance/search-full-test.js
+++ b/test/javascripts/acceptance/search-full-test.js
@@ -172,72 +172,6 @@ QUnit.test("update category through advanced search ui", async assert => {
-// test("update group through advanced search ui", assert => {
-//   visit("/search");
-//   fillIn('.search-query', 'none');
-//   fillIn('.search-advanced-options .group-selector', 'moderators');
-//   click('.search-advanced-options .group-selector');
-//   keyEvent('.search-advanced-options .group-selector', 'keydown', 8);
-//   andThen(() => {
-//     waitFor(() => {
-//       assert.ok(visible('.search-advanced-options .autocomplete'), '"autocomplete" popup is visible');
-//       assert.ok(exists('.search-advanced-options .autocomplete ul li a:contains("moderators")'), '"autocomplete" popup has an entry for "moderators"');
-//       click('.search-advanced-options .autocomplete ul li a:first');
-//       andThen(() => {
-//         assert.ok(exists('.search-advanced-options span:contains("moderators")'), 'has "moderators" pre-populated');
-//         assert.equal(find('.search-query').val(), "none group:moderators", 'has updated search term to "none group:moderators"');
-// test("update badges through advanced search ui", assert => {
-//   fillIn('.search-advanced-options .badge-names', 'Reader');
-//   click('.search-advanced-options .badge-names');
-//   keyEvent('.search-advanced-options .badge-names', 'keydown', 8);
-//   andThen(() => {
-//     waitFor(() => {
-//       assert.ok(exists('.search-advanced-options .autocomplete ul li a:contains("Reader")'), '"autocomplete" popup has an entry for "Reader"');
-//       andThen(() => {
-//         assert.ok(exists('.search-advanced-options span:contains("Reader")'), 'has "Reader" pre-populated');
-//         assert.equal(find('.search-query').val(), "none badge:Reader", 'has updated search term to "none badge:Reader"');
-// test("update tags through advanced search ui", assert => {
-//   keyEvent('.search-advanced-options .tag-chooser input.select2-input', 'keydown', 110);
-//   fillIn('.search-advanced-options .tag-chooser input.select2-input', 'monkey');
-//   keyEvent('.search-advanced-options .tag-chooser input.select2-input', 'keyup', 110);
-//   andThen(() => {
-//     waitFor(() => {
-//       click('li.select2-result-selectable:first');
-//       andThen(() => {
-//         assert.ok(exists('.search-advanced-options .tag-chooser .tag-monkey'), 'has "monkey" pre-populated');
-//         assert.equal(find('.search-query').val(), "none tags:monkey", 'has updated search term to "none tags:monkey"');
 QUnit.test(
   "update in:title filter through advanced search ui",
   async assert => {
GitHub sha: fe2d5da6
