DEV: Remove rb-inotify gem from Gemfile (PR #10574)
We are no longer directly referencing the rb-inotify gem directly in code. This was just a spec level dependency anyways.
Using git log -S "Inotify" resulted in these two commits as usages of Inotify:
  • b56b11d96aafa5cd9e2f004ae631348fba4574ae
  • 9cf03b352cb2bff7c9a7a56211d56a921ed13664
both from 2013, but we no longer are using inotify in
https://github.com/discourse/discourse/blob/master/lib/tasks/autospec.rake
which appears to be the only file that was using it.
Based on this info we can safely remove rb-inotify from the Gemfile.
Just as a side note we still do have a couple of gems that do have rb-inotify as a dependency: listen, and lru_redux.
I didn’t add any additional tests because if one of the tests was actually using this gem I would hope that it would fail.
GitHub
Looks good to me :+1:
