DEV: Remove reference to very old plugin (#13098)
diff --git a/lib/plugin/instance.rb b/lib/plugin/instance.rb
index 380a63e..784a028 100644
--- a/lib/plugin/instance.rb
+++ b/lib/plugin/instance.rb
@@ -86,10 +86,6 @@ class Plugin::Instance
     [].tap { |plugins|
       # also follows symlinks - http://stackoverflow.com/q/357754
       Dir["#{parent_path}/*/plugin.rb"].sort.each do |path|
-        # tagging is included in core, so don't load it
-        next if path =~ /discourse-tagging/
         source = File.read(path)
         metadata = Plugin::Metadata.parse(source)
         plugins << self.new(metadata, path)
GitHub sha: e2f9da97
This commit appears in #13098 which was approved by CvX and ZogStriP. It was merged by udan11.
