DEV: Remove `suspend` from Admin::UsersController responses (#8206)
DEV: Remove suspend from Admin::UsersController responses (#8206)
suspend isn’t a User attribute, but was being assigned to the frontend User model as if it was. The model has a computed property that depends on suspended_till, so instead of overriding this property, it’s better to return relevant attributes.
Fixes a computed-property.override deprecation (https://emberjs.com/deprecations/v3.x#toc_computed-property-override)
diff --git a/app/controllers/admin/users_controller.rb b/app/controllers/admin/users_controller.rb
index 8c860a4d89..3261e8149a 100644
--- a/app/controllers/admin/users_controller.rb
+++ b/app/controllers/admin/users_controller.rb
@@ -137,7 +137,6 @@ class Admin::UsersController < Admin::AdminController
     render_json_dump(
       suspension: {
-        suspended: true,
         suspend_reason: params[:reason],
         full_suspend_reason: user_history.try(:details),
         suspended_till: @user.suspended_till,
@@ -157,7 +156,8 @@ class Admin::UsersController < Admin::AdminController
     render_json_dump(
       suspension: {
-        suspended: false
+        suspended_till: nil,
+        suspended_at: nil
diff --git a/test/javascripts/acceptance/admin-suspend-user-test.js.es6 b/test/javascripts/acceptance/admin-suspend-user-test.js.es6
index 152b035b60..d9983848ca 100644
--- a/test/javascripts/acceptance/admin-suspend-user-test.js.es6
+++ b/test/javascripts/acceptance/admin-suspend-user-test.js.es6
@@ -8,7 +8,7 @@ acceptance("Admin - Suspend User", {
     server.put("/admin/users/:user_id/suspend", () =>
       helper.response(200, {
         suspension: {
-          suspended: true
+          suspended_till: "2099-01-01T12:00:00.000Z"
@@ -16,7 +16,7 @@ acceptance("Admin - Suspend User", {
     server.put("/admin/users/:user_id/unsuspend", () =>
         suspension: {
-          suspended: false
+          suspended_till: null
GitHub sha: f6ea986a
This seems OK but is technically a breaking change on the API. Did you check to see if any plugins are depending on that format?
The admin API for suspending and unsuspending a user, to be precise. I’m not aware of any plugins using those, and couldn’t find any code referencing these endpoints in the Discourse org (other than the core frontend).
