DEV: Remove the remaining Travis code (#13255)
The second attempt at #10041 now that all our plugins use GitHub Actions CI instead.
diff --git a/lib/tasks/docker.rake b/lib/tasks/docker.rake
index feafbfc..5d66206 100644
--- a/lib/tasks/docker.rake
+++ b/lib/tasks/docker.rake
@@ -59,9 +59,9 @@ desc 'Run all tests (JS and code in a standalone environment)'
 task 'docker:test' do
   begin
     @good = true
     unless ENV['SKIP_LINT']
       @good &&= run_or_fail("yarn install")
-      puts "travis_fold:start:lint" if ENV["TRAVIS"]
       puts "Running linters/prettyfiers"
       puts "eslint #{`yarn eslint -v`}"
       puts "prettier #{`yarn prettier -v`}"
@@ -94,11 +94,9 @@ task 'docker:test' do
           @good &&= run_or_fail('yarn prettier --list-different "plugins/**/assets/stylesheets/**/*.scss" "plugins/**/assets/javascripts/**/*.{js,es6}"')
-      puts "travis_fold:end:lint" if ENV["TRAVIS"]
     unless ENV['SKIP_TESTS']
-      puts "travis_fold:start:prepare_tests" if ENV["TRAVIS"]
       puts "Cleaning up old test tmp data in tmp/test_data"
       `rm -fr tmp/test_data && mkdir -p tmp/test_data/redis && mkdir tmp/test_data/pg`
@@ -156,11 +154,7 @@ task 'docker:test' do
         @good &&= run_or_fail("#{command_prefix}bundle exec rake parallel:migrate")
-      puts "travis_fold:end:prepare_tests" if ENV["TRAVIS"]
       unless ENV["JS_ONLY"]
-        puts "travis_fold:start:ruby_tests" if ENV["TRAVIS"]
         if ENV['WARMUP_TMP_FOLDER']
           run_or_fail('bundle exec rspec ./spec/requests/groups_controller_spec.rb')
@@ -211,13 +205,11 @@ task 'docker:test' do
             @good &&= run_or_fail("#{fail_fast} bundle exec rake plugin:spec")
-        puts "travis_fold:end:ruby_tests" if ENV["TRAVIS"]
       unless ENV["RUBY_ONLY"]
         js_timeout = ENV["JS_TIMEOUT"].presence || 900_000 # 15 minutes
-        puts "travis_fold:start:js_tests" if ENV["TRAVIS"]
         unless ENV["SKIP_CORE"]
           @good &&= run_or_fail("bundle exec rake qunit:test['#{js_timeout}']")
           @good &&= run_or_fail("bundle exec rake qunit:test['#{js_timeout}','/wizard/qunit']")
@@ -237,13 +229,9 @@ task 'docker:test' do
             @good &&= run_or_fail("yarn ember test")
-        puts "travis_fold:end:js_tests" if ENV["TRAVIS"]
   ensure
-    puts "travis_fold:start:terminating" if ENV["TRAVIS"]
     puts "Terminating"
     if ENV['PAUSE_ON_TERMINATE']
@@ -255,11 +243,7 @@ task 'docker:test' do
     Process.kill("TERM", @pg_pid) if @pg_pid
     Process.wait @redis_pid if @redis_pid
     Process.wait @pg_pid if @pg_pid
-    puts "travis_fold:end:terminating" if ENV["TRAVIS"]
-  end
-  if !@good
-    exit 1
+  exit 1 unless @good
diff --git a/lib/tasks/qunit.rake b/lib/tasks/qunit.rake
index 733d275..bbeaba8 100644
--- a/lib/tasks/qunit.rake
+++ b/lib/tasks/qunit.rake
@@ -96,17 +96,7 @@ task "qunit:test", [:timeout, :qunit_path] do |_, args|
     puts "Rails server is warmed up"
     sh(cmd)
-    # A bit of a hack until we can figure this out on Travis
-    tries = 0
-    while tries < 3 && $?.exitstatus == 124
-      tries += 1
-      puts "\nTimed Out. Trying again...\n"
-      sh(cmd)
-    end
     success &&= $?.success?
   ensure
     # was having issues with HUP
     Process.kill "-KILL", pid
diff --git a/script/docker_test.rb b/script/docker_test.rb
index 3696a53..db73d53 100644
--- a/script/docker_test.rb
+++ b/script/docker_test.rb
@@ -8,8 +8,6 @@
 # => RUN_SMOKE_TESTS  executes the smoke tests instead of the regular tests from docker.rake
 # See lib/tasks/docker.rake and lib/tasks/smoke_test.rake for more information
-puts "travis_fold:end:starting_docker_container" if ENV["TRAVIS"]
 def log(message)
   puts "[#{Time.now.strftime("%Y-%m-%d %H:%M:%S")}] #{message}"
@@ -22,24 +20,17 @@ def run_or_fail(command)
 unless ENV['NO_UPDATE']
-  puts "travis_fold:start:pulling_latest_discourse" if ENV["TRAVIS"]
   run_or_fail("git reset --hard")
   run_or_fail("git fetch")
   checkout = ENV['COMMIT_HASH'] || "FETCH_HEAD"
   run_or_fail("LEFTHOOK=0 git checkout #{checkout}")
-  puts "travis_fold:end:pulling_latest_discourse" if ENV["TRAVIS"]
-  puts "travis_fold:start:bundle" if ENV["TRAVIS"]
   run_or_fail("bundle")
-  puts "travis_fold:end:bundle" if ENV["TRAVIS"]
 log("Running tests")
 if ENV['RUN_SMOKE_TESTS']
   run_or_fail("bundle exec rake smoke:test")
 else
diff --git a/spec/models/optimized_image_spec.rb b/spec/models/optimized_image_spec.rb
index c662933..345a6ba 100644
--- a/spec/models/optimized_image_spec.rb
+++ b/spec/models/optimized_image_spec.rb
@@ -6,31 +6,29 @@ describe OptimizedImage do
   let(:upload) { build(:upload) }
   before { upload.id = 42 }
-  unless ENV["TRAVIS"]
-    describe '.crop' do
-      it 'should produce cropped images (requires ImageMagick 7)' do
-        tmp_path = "/tmp/cropped.png"
+  describe '.crop' do
+    it 'should produce cropped images (requires ImageMagick 7)' do
+      tmp_path = "/tmp/cropped.png"
-        begin
-          OptimizedImage.crop(
-            "#{Rails.root}/spec/fixtures/images/logo.png",
-            tmp_path,
-            5,
-            5
+      begin
+        OptimizedImage.crop(
+          "#{Rails.root}/spec/fixtures/images/logo.png",
+          tmp_path,
+          5,
+          5
-          # we don't want to deal with something new here every time image magick
-          # is upgraded or pngquant is upgraded, lets just test the basics ...
-          # cropped image should be less than 120 bytes
+        # we don't want to deal with something new here every time image magick
+        # is upgraded or pngquant is upgraded, lets just test the basics ...
+        # cropped image should be less than 120 bytes
-          cropped_size = File.size(tmp_path)
+        cropped_size = File.size(tmp_path)
-          expect(cropped_size).to be < 120
-          expect(cropped_size).to be > 50
+        expect(cropped_size).to be < 120
+        expect(cropped_size).to be > 50
-        ensure
-          File.delete(tmp_path) if File.exists?(tmp_path)
-        end
+      ensure
+        File.delete(tmp_path) if File.exists?(tmp_path)
diff --git a/spec/requests/user_avatars_controller_spec.rb b/spec/requests/user_avatars_controller_spec.rb
index 6a3d7fb..0abf673 100644
--- a/spec/requests/user_avatars_controller_spec.rb
+++ b/spec/requests/user_avatars_controller_spec.rb
@@ -3,7 +3,6 @@
 require 'rails_helper'
 describe UserAvatarsController do
   context 'show_proxy_letter' do
     it 'returns not found if external avatar is set somewhere else' do
       SiteSetting.external_system_avatars_url = "https://somewhere.else.com/avatar.png"
@@ -19,52 +18,48 @@ describe UserAvatarsController do
   context 'show' do
+    context 'invalid' do
+      after do
+        FileUtils.rm(Discourse.store.path_for(upload))
+      end
-    # travis is not good here, no image magick
-    if !ENV["TRAVIS"]
-      context 'invalid' do
-        after do
-          FileUtils.rm(Discourse.store.path_for(upload))
-        end
-        let :upload do
-          File.open(file_from_fixtures("cropped.png")) do |f|
-            UploadCreator.new(
-              f,
-              "test.png"
-            ).create_for(-1)
-          end
+      let :upload do
+        File.open(file_from_fixtures("cropped.png")) do |f|
+          UploadCreator.new(
+            f,
+            "test.png"
+          ).create_for(-1)
+      end
-        let :user do
-          user = Fabricate(:user)
-          user.user_avatar.update_columns(custom_upload_id: upload.id)
-          user.update_columns(uploaded_avatar_id: upload.id)
-          user
-        end
+      let(:user) do
+        user = Fabricate(:user)
+        user.user_avatar.update_columns(custom_upload_id: upload.id)
+        user.update_columns(uploaded_avatar_id: upload.id)
+        user
GitHub sha: 3bb765ac
This commit appears in #13255 which was approved by pmusaraj. It was merged by CvX.
