DEV: Remove underscore from `learn_more` key in theme export
DEV: Remove underscore from learn_more key in theme export
Follow up from 033cd4f3
diff --git a/app/models/theme.rb b/app/models/theme.rb
index fe4375c..3b0be21 100644
--- a/app/models/theme.rb
+++ b/app/models/theme.rb
@@ -455,7 +455,7 @@ class Theme < ActiveRecord::Base
-      meta[:_learn_more] = "https://meta.discourse.org/t/beginners-guide-to-using-discourse-themes/91966"
+      meta[:learn_more] = "https://meta.discourse.org/t/beginners-guide-to-using-discourse-themes/91966"
diff --git a/spec/components/theme_store/tgz_exporter_spec.rb b/spec/components/theme_store/tgz_exporter_spec.rb
index eb3104e..fb9f32d 100644
--- a/spec/components/theme_store/tgz_exporter_spec.rb
+++ b/spec/components/theme_store/tgz_exporter_spec.rb
@@ -89,7 +89,7 @@ describe ThemeStore::TgzExporter do
             "tertiary": "858585"
-        "_learn_more": "https://meta.discourse.org/t/beginners-guide-to-using-discourse-themes/91966"
+        "learn_more": "https://meta.discourse.org/t/beginners-guide-to-using-discourse-themes/91966"
       expect(File.read("common/body_tag.html")).to eq("<b>testtheme1</b>")
GitHub sha: fb5c9424
