DEV: Remove unused after block in tests.
diff --git a/spec/connection_management_spec.rb b/spec/connection_management_spec.rb
index b6f91dd..fba9a6b 100644
--- a/spec/connection_management_spec.rb
+++ b/spec/connection_management_spec.rb
@@ -40,10 +40,6 @@ describe RailsMultisite::ConnectionManagement do
     context 'current' do
-      after do
-        ActiveRecord::Base.connection_handler.clear_all_connections!
-      end
       it "has default current db" do
         expect(conn.current_db).to eq('default')
GitHub sha: 51bd649f
