DEV: Remove unused autoload path.
diff --git a/config/application.rb b/config/application.rb
index 020f287..3b38209 100644
--- a/config/application.rb
+++ b/config/application.rb
@@ -111,7 +111,6 @@ module Discourse
     config.autoload_paths += Dir["#{config.root}/app/jobs"]
     config.autoload_paths += Dir["#{config.root}/app/serializers"]
     config.autoload_paths += Dir["#{config.root}/lib"]
-    config.autoload_paths += Dir["#{config.root}/lib/active_record/connection_adapters"]
     config.autoload_paths += Dir["#{config.root}/lib/common_passwords"]
     config.autoload_paths += Dir["#{config.root}/lib/highlight_js"]
     config.autoload_paths += Dir["#{config.root}/lib/i18n"]
GitHub sha: 7a98efe7
This commit appears in #12957 which was approved by lis2. It was merged by tgxworld.
