DEV: Remove unused code from `TopicView`. (#14605)
DEV: Remove unused code from TopicView. (#14605)
diff --git a/lib/topic_view.rb b/lib/topic_view.rb
index 1f4817e..bcd6134 100644
--- a/lib/topic_view.rb
+++ b/lib/topic_view.rb
@@ -87,7 +87,6 @@ class TopicView
     check_and_raise_exceptions(options[:skip_staff_action])
     @message_bus_last_id = MessageBus.last_id("/topic/#{@topic.id}")
-    @print = options[:print].present?
     options.each do |key, value|
       self.instance_variable_set("@#{key}".to_sym, value)
@@ -109,10 +108,6 @@ class TopicView
     @page = @page.to_i > 1 ? @page.to_i : calculate_page
     setup_filtered_posts
-    @initial_load = true
-    @index_reverse = false
     filter_posts(options)
     if @posts && !@skip_custom_fields
@@ -317,13 +312,6 @@ class TopicView
     @group_names = result
-  # Find the sort order for a post in the topic
-  def sort_order_for_post_number(post_number)
-    posts = Post.where(topic_id: @topic.id, post_number: post_number).with_deleted
-    posts = filter_post_types(posts)
-    posts.select(:sort_order).first.try(:sort_order)
-  end
   # Filter to all posts near a particular post number
   def filter_posts_near(post_number)
     posts_before = (@limit.to_f / 4).floor
@@ -564,12 +552,6 @@ class TopicView
     @link_counts ||= TopicLink.counts_for(@guardian, @topic, posts)
-  # Are we the initial page load? If so, we can return extra information like
-  # user post counts, etc.
-  def initial_load?
-    @initial_load
-  end
   def pm_params
     @pm_params ||= TopicQuery.new(@user).get_pm_params(topic)
GitHub sha: c34c24ffe4bcf2ce1b381dc1e0078d841535f844
This commit appears in #14605 which was approved by CvX. It was merged by tgxworld.
