DEV: Remove unused comments from tests. (#13241)
Fabrication does not guarantee the ordering of records in anyway.
diff --git a/spec/models/report_spec.rb b/spec/models/report_spec.rb
index 36ffeb0..1611bb7 100644
--- a/spec/models/report_spec.rb
+++ b/spec/models/report_spec.rb
@@ -3,10 +3,10 @@
 require 'rails_helper'
 describe Report do
-  let(:user) { Fabricate(:user) }  # id: 3
-  let(:c0) { Fabricate(:category, user: user) }  # id: 3
+  let(:user) { Fabricate(:user) }
+  let(:c0) { Fabricate(:category, user: user) }
   let(:c1) { Fabricate(:category, parent_category: c0, user: user) }  # id: 2
-  let(:c2) { Fabricate(:category, user: user) }  # id: 4
+  let(:c2) { Fabricate(:category, user: user) }
   shared_examples 'no data' do
     context "with no data" do
GitHub sha: c809f722
This commit appears in #13241 which was approved by SamSaffron. It was merged by SamSaffron.
