DEV: Remove unused DiscoursePlugin class (#9715)
diff --git a/config/application.rb b/config/application.rb
index 3eb998a..fab55ac 100644
--- a/config/application.rb
+++ b/config/application.rb
@@ -23,7 +23,6 @@ require 'sprockets/railtie'
 # Plugin related stuff
 require_relative '../lib/plugin_initialization_guard'
 require_relative '../lib/discourse_event'
-require_relative '../lib/discourse_plugin'
 require_relative '../lib/discourse_plugin_registry'
 require_relative '../lib/plugin_gem'
diff --git a/lib/discourse_plugin.rb b/lib/discourse_plugin.rb
deleted file mode 100644
index 5d687e0..0000000
--- a/lib/discourse_plugin.rb
+++ /dev/null
@@ -1,52 +0,0 @@
-# frozen_string_literal: true
-# A basic plugin for Discourse. Meant to be extended and filled in.
-# Most work is delegated to a registry.
-class DiscoursePlugin
-  attr_reader :registry
-  def initialize(registry)
-    @registry = registry
-  end
-  def setup
-    # Initialize the plugin here
-  end
-  # Loads and mixes in the plugin's mixins into the host app's classes.
-  # A mixin named "UserMixin" will be included into the "User" class.
-  def self.include_mixins
-    mixins.each do |mixin|
-      original_class = mixin.to_s.demodulize.sub("Mixin", "")
-      dependency_file_name = original_class.underscore
-      require_dependency(dependency_file_name)
-      original_class.constantize.public_send(:include, mixin)
-    end
-  end
-  # Find the modules defined in the plugin with "Mixin" in their name.
-  def self.mixins
-    constants.map { |const_name| const_get(const_name) }
-      .select { |const| const.class == Module && const.name["Mixin"] }
-  end
-  def register_js(file, opts = {})
-    @registry.register_js(file, opts)
-  end
-  def register_css(file, plugin_directory_name)
-    @registry.register_css(file, plugin_directory_name)
-  end
-  def register_archetype(name, options = {})
-    @registry.register_archetype(name, options)
-  end
-  def listen_for(event_name)
-    return unless self.respond_to?(event_name)
-    DiscourseEvent.on(event_name, &self.method(event_name))
-  end
-end
diff --git a/lib/discourse_plugin_registry.rb b/lib/discourse_plugin_registry.rb
index 8e9dde7..2022c24 100644
--- a/lib/discourse_plugin_registry.rb
+++ b/lib/discourse_plugin_registry.rb
@@ -296,10 +296,4 @@ class DiscoursePluginRegistry
     locales.clear
-  def self.setup(plugin_class)
-    registry = DiscoursePluginRegistry.new
-    plugin = plugin_class.new(registry)
-    plugin.setup
-  end
diff --git a/spec/components/discourse_plugin_spec.rb b/spec/components/discourse_plugin_spec.rb
index 12a19d9..0000000
--- a/spec/components/discourse_plugin_spec.rb
+++ /dev/null
@@ -1,56 +0,0 @@
-require 'rails_helper'
-describe DiscoursePlugin do
-  class TestPlugin < DiscoursePlugin
-    module SomeModule
-    end
-    module TestMixin
-    end
-  end
-  let(:registry) { mock }
-  let(:plugin) { TestPlugin.new(registry) }
-  describe ".mixins" do
-    it "finds its mixins" do
-      expect(TestPlugin.mixins).to eq([TestPlugin::TestMixin])
-    end
-  end
-  it "delegates adding js to the registry" do
-    registry.expects(:register_js).with('test.js', any_parameters)
-    plugin.register_js('test.js')
-  end
-  it "delegates adding css to the registry" do
-    registry.expects(:register_css).with('test.css', 'test')
-    plugin.register_css('test.css', 'test')
-  end
-  it "delegates creating archetypes" do
-    registry.expects(:register_archetype).with('banana', oh: 'no!')
-    plugin.register_archetype('banana', oh: 'no!')
-  end
-  context 'registering for callbacks' do
-    before do
-      plugin.stubs(:hello)
-      @proc = plugin.listen_for(:hello).first
-    end
-    after do
-      DiscourseEvent.off(:hello, &@proc)
-    end
-    it "calls the method when it is triggered" do
-      plugin.expects(:hello).with('there')
-      DiscourseEvent.trigger(:hello, 'there')
-    end
-  end
-end
GitHub sha: 5fc51ed4
This commit appears in #9715 which was approved by eviltrout. It was merged by davidtaylorhq.
