DEV: Remove unused rswag script
We no longer use this script for helping generate rswag formatted docs because we can use json schema now.
diff --git a/script/json_to_rswag.rb b/script/json_to_rswag.rb
deleted file mode 100644
index e3e25ea..0000000
--- a/script/json_to_rswag.rb
+++ /dev/null
@@ -1,101 +0,0 @@
-# frozen_string_literal: true
-require 'json'
-# This script is used for development to help document rswag api responses.  It
-# takes a json response string as an input and converts it to ruby in the format
-# that rswag wants so that you can copy+paste it into the appropriate spec rather
-# than typing it by hand.
-# example:
-# ruby script/json_to_rswag.rb '{"success":true,"active":true,"message":"Your account is activated and ready to use.","user_id":18}'
-# will output:
-# schema type: :object, properties: {
-#   success: { type: :boolean },
-#   active: { type: :boolean },
-#   message: { type: :string },
-#   user_id: { type: :integer },
-class JsonToRswag
-  def initialize
-    @output = Array.new
-    @output.push("schema type: :object, properties: {")
-  end
-  def get_type(k, v)
-    type = ""
-    type = "integer" if v.is_a? Integer
-    type = "number" if v.is_a? Float
-    type = "object" if v.is_a? Hash
-    type = "array" if v.is_a? Array
-    type = "boolean" if v == true || v == false
-    type = "null" if v == nil
-    type = "string" if v.is_a? String
-    if type == ""
-      puts "Cannot determine type for:"
-      puts v
-      exit 1
-    end
-    type
-  end
-  def run(h, indent)
-    h.each do |k, v|
-      type = get_type(k, v)
-      if type == "object"
-        @output << "#{' ' * indent}#{k}: {"
-        @output << "#{' ' * (indent + 2)}type: :object,"
-        @output << "#{' ' * (indent + 2)}properties: {"
-        run(v, indent + 4)
-        @output << "#{' ' * indent}},"
-      end
-      if type == "array"
-        @output << "#{' ' * (indent + 2)}type: :array,"
-        @output << "#{' ' * (indent + 2)}items: {"
-        a = v.first
-        if a.is_a? Hash
-          @output << "#{' ' * (indent + 4)}type: :object,"
-          @output << "#{' ' * (indent + 4)}properties: {"
-          run(a , indent + 6)
-          @output << "#{' ' * (indent + 2)}},"
-        else
-        end
-      end
-      if type == "null"
-        @output << "#{' ' * indent}#{k}: { type: :string, nullable: true },"
-      elsif type != "object" && type != "array"
-        @output << "#{' ' * indent}#{k}: { type: :#{type} },"
-      end
-    end
-    @output << "#{' ' * (indent - 2)}}"
-  end
-  def print
-    puts @output
-  end
-end
-input = ARGV[0]
-if input == nil || input == ""
-  puts "Please pass in a json string."
-  exit 1
-end
-json = JSON.parse(input)
-json_to_rswag = JsonToRswag.new
-json_to_rswag.run(json, 2)
-json_to_rswag.print
GitHub sha: 4b7b5868
This commit appears in #12974 which was approved by tgxworld. It was merged by tgxworld.
