DEV: remove unused sshd template
No need to carry this template anymore we do not use it.
diff --git a/templates/sshd.template.yml b/templates/sshd.template.yml
deleted file mode 100644
index 605a11d..0000000
--- a/templates/sshd.template.yml
+++ /dev/null
@@ -1,49 +0,0 @@
-params:
-  # SSH key is required for remote access into the container
-  # you may also use ssh-import-id
-  ssh_key: ""
-  # so ssh-import-id works
-env:
-  HOME: /root
-run:
-  - file:
-     path: /etc/service/sshd/run
-     chmod: "+x"
-     contents: |
-        #!/bin/bash
-        exec 2>&1
-        exec /usr/sbin/sshd -D -e
-  - file:
-     path: /etc/runit/3.d/99-ssh
-     chmod: "+x"
-     contents: |
-       #!/bin/bash
-       sv stop sshd
-  - exec:
-      hook: sshd
-      cmd:
-        - apt -y install openssh-server
-        - mkdir -p /var/run/sshd
-        - mkdir -p /root/.ssh
-        - echo "$ssh_key" >> /root/.ssh/authorized_keys
-        - echo "$$ENV_SSH_PUB_KEY" >> /root/.ssh/authorized_keys
-        - chmod 640 /root/.ssh/authorized_keys
-  - replace:
-      filename: /etc/pam.d/sshd
-      to: ""
-  - file:
-     path: /etc/update-motd.d/00-discourse
-     chmod: +x
-     contents: |
-        #!/bin/sh
-        echo
-        echo Welcome to Discourse Docker
-        echo
GitHub sha: 8c8dbd03
https://meta.discourse.org/t/difficulties-with-app-rebuild/150285/5
