DEV: Remove useless ordering when searching within a topic. (#14676)
Searching within a topic currently does not make use of PG search and we’re simply doing an ilike against the post raw. Furthermore, Post#post_number is already unique within a topic so the other ordering will never ever be used. This change simply makes the query cleaner to read.
diff --git a/lib/search.rb b/lib/search.rb
index dd5581d..231b5df 100644
--- a/lib/search.rb
+++ b/lib/search.rb
@@ -93,7 +93,6 @@ class Search
         data = data.join(' ')
       else
         data.squish!
@@ -990,7 +989,7 @@ class Search
             .push(@search_context.id)
           posts.where("topics.category_id in (?)", category_ids)
-        elsif @search_context.is_a?(Topic)
+        elsif is_topic_search
           posts.where("topics.id = #{@search_context.id}")
             .order("posts.post_number #{@order == :latest ? "DESC" : ""}")
         elsif @search_context.is_a?(Tag)
@@ -1028,7 +1027,7 @@ class Search
       else
         posts = posts.order("posts.like_count DESC")
-    else
+    elsif !is_topic_search
       rank = <<~SQL
       TS_RANK_CD(
         post_search_data.search_data,
GitHub sha: 6544e3b02a0013e571aa8d226cb3591fcdd945b3
This commit appears in #14676 which was approved by pmusaraj. It was merged by tgxworld.
