DEV: Remove xlink hrefs (#15059)
diff --git a/app/assets/javascripts/discourse-common/addon/lib/icon-library.js b/app/assets/javascripts/discourse-common/addon/lib/icon-library.js
index e6c740b..edf8160 100644
--- a/app/assets/javascripts/discourse-common/addon/lib/icon-library.js
+++ b/app/assets/javascripts/discourse-common/addon/lib/icon-library.js
@@ -149,7 +149,7 @@ registerIconRenderer({
     if (params.label) {
       html += " aria-hidden='true'";
-    html += ` xmlns="${SVG_NAMESPACE}"><use xlink:href="#${id}" /></svg>`;
+    html += ` xmlns="${SVG_NAMESPACE}"><use href="#${id}" /></svg>`;
     if (params.label) {
       html += `<span class='sr-only'>${escape(params.label)}</span>`;
@@ -178,10 +178,7 @@ registerIconRenderer({
         h("use", {
-          "xlink:href": attributeHook(
-            "http://www.w3.org/1999/xlink",
-            `#${escape(id)}`
+          href: attributeHook("http://www.w3.org/1999/xlink", `#${escape(id)}`),
           namespace: SVG_NAMESPACE,
diff --git a/app/assets/javascripts/discourse/app/lib/plugin-api.js b/app/assets/javascripts/discourse/app/lib/plugin-api.js
index 5d7d924..b897b21 100644
--- a/app/assets/javascripts/discourse/app/lib/plugin-api.js
+++ b/app/assets/javascripts/discourse/app/lib/plugin-api.js
@@ -234,7 +234,7 @@ class PluginApi {
    *   // for the place in code that render a string
    *   string() {
-   *     return "<svg class=\"fa d-icon d-icon-far-smile svg-icon\" aria-hidden=\"true\"><use xlink:href=\"#far-smile\"></use></svg>";
+   *     return "<svg class=\"fa d-icon d-icon-far-smile svg-icon\" aria-hidden=\"true\"><use href=\"#far-smile\"></use></svg>";
    *   // for the places in code that render virtual dom elements
@@ -244,7 +244,7 @@ class PluginApi {
    *          namespace: "http://www.w3.org/2000/svg"
    *          h("use", {
-   *          "xlink:href": attributeHook("http://www.w3.org/1999/xlink", `#far-smile`),
+   *          "href": attributeHook("http://www.w3.org/1999/xlink", `#far-smile`),
diff --git a/app/assets/javascripts/discourse/app/templates/components/login-buttons.hbs b/app/assets/javascripts/discourse/app/templates/components/login-buttons.hbs
index cba646b..f334a04 100644
--- a/app/assets/javascripts/discourse/app/templates/components/login-buttons.hbs
+++ b/app/assets/javascripts/discourse/app/templates/components/login-buttons.hbs
@@ -1,7 +1,7 @@
 {{#each buttons as |b|}}
   <button type="button" class="btn btn-social {{b.name}}" {{action externalLogin b}} aria-label={{b.screenReaderTitle}} tabindex="3">
     {{#if b.isGoogle}}
-      <svg class="fa d-icon d-icon-custom-google-oauth2 svg-icon" xmlns="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink" viewBox="0 0 48 48"><defs><path id="a" d="M44.5 20H24v8.5h11.8C34.7 33.9 30.1 37 24 37c-7.2 0-13-5.8-13-13s5.8-13 13-13c3.1 0 5.9 1.1 8.1 2.9l6.4-6.4C34.6 4.1 29.6 2 24 2 11.8 2 2 11.8 2 24s9.8 22 22 22c11 0 21-8 21-22 0-1.3-.2-2.7-.5-4z"/></defs><clipPath id="b"><use xlink:href="#a" overflow="visible"/></clipPath><path clip-path="url(#b)" fill="#FBBC05" d="M0 37V11l17 13z"/><path clip-path="url(#b)" fill="#EA4335" d="M0 11l17 13 7-6.1L48 14V0H0z"/><path clip-path="url(#b)" fill="#34A853" d="M0 37l30-23 7.9 1L48 0v48H0z"/><path clip-path="url(#b)" fill="#4285F4" d="M48 48L17 24l-4-3 35-10z"/></svg>
+      <svg class="fa d-icon d-icon-custom-google-oauth2 svg-icon" viewBox="0 0 48 48"><defs><path id="a" d="M44.5 20H24v8.5h11.8C34.7 33.9 30.1 37 24 37c-7.2 0-13-5.8-13-13s5.8-13 13-13c3.1 0 5.9 1.1 8.1 2.9l6.4-6.4C34.6 4.1 29.6 2 24 2 11.8 2 2 11.8 2 24s9.8 22 22 22c11 0 21-8 21-22 0-1.3-.2-2.7-.5-4z"/></defs><clipPath id="b"><use href="#a" overflow="visible"/></clipPath><path clip-path="url(#b)" fill="#FBBC05" d="M0 37V11l17 13z"/><path clip-path="url(#b)" fill="#EA4335" d="M0 11l17 13 7-6.1L48 14V0H0z"/><path clip-path="url(#b)" fill="#34A853" d="M0 37l30-23 7.9 1L48 0v48H0z"/><path clip-path="url(#b)" fill="#4285F4" d="M48 48L17 24l-4-3 35-10z"/></svg>
     {{else if b.icon}}
       {{d-icon b.icon}}
     {{else}}
diff --git a/app/assets/javascripts/discourse/tests/acceptance/bookmarks-test.js b/app/assets/javascripts/discourse/tests/acceptance/bookmarks-test.js
index cd0a9bf..5f8a186 100644
--- a/app/assets/javascripts/discourse/tests/acceptance/bookmarks-test.js
+++ b/app/assets/javascripts/discourse/tests/acceptance/bookmarks-test.js
@@ -62,7 +62,7 @@ acceptance("Bookmarking", function (needs) {
   topicResponse.post_stream.posts[0].cooked += `<span data-date="2036-01-15" data-time="00:35:00" class="discourse-local-date cooked-date past" data-timezone="Europe/London">
   <span>
     <svg class="fa d-icon d-icon-globe-americas svg-icon" xmlns="http://www.w3.org/2000/svg">
-      <use xlink:href="#globe-americas"></use>
+      <use href="#globe-americas"></use>
     </svg>
     <span class="relative-time">January 15, 2036 12:35 AM</span>
   </span>
@@ -71,7 +71,7 @@ acceptance("Bookmarking", function (needs) {
   topicResponse.post_stream.posts[1].cooked += `<span data-date="2021-01-15" data-time="00:35:00" class="discourse-local-date cooked-date past" data-timezone="Europe/London">
   <span>
     </svg>
     <span class="relative-time">Today 10:30 AM</span>
   </span>
diff --git a/app/assets/javascripts/discourse/tests/integration/components/d-icon-test.js b/app/assets/javascripts/discourse/tests/integration/components/d-icon-test.js
index cb3a2bd..38e79c1 100644
--- a/app/assets/javascripts/discourse/tests/integration/components/d-icon-test.js
+++ b/app/assets/javascripts/discourse/tests/integration/components/d-icon-test.js
@@ -17,7 +17,7 @@ discourseModule("Integration | Component | d-icon", function (hooks) {
       const html = queryAll(".test").html().trim();
       assert.strictEqual(
         html,
-        '<svg class="fa d-icon d-icon-bars svg-icon svg-string" xmlns="http://www.w3.org/2000/svg"><use xlink:href="#bars"></use></svg>'
+        '<svg class="fa d-icon d-icon-bars svg-icon svg-string" xmlns="http://www.w3.org/2000/svg"><use href="#bars"></use></svg>'
@@ -29,7 +29,7 @@ discourseModule("Integration | Component | d-icon", function (hooks) {
       assert.strictEqual(
         html,
-        '<svg class="fa d-icon d-icon-d-watching svg-icon svg-string" xmlns="http://www.w3.org/2000/svg"><use xlink:href="#discourse-bell-exclamation"></use></svg>'
+        '<svg class="fa d-icon d-icon-d-watching svg-icon svg-string" xmlns="http://www.w3.org/2000/svg"><use href="#discourse-bell-exclamation"></use></svg>'
diff --git a/app/assets/javascripts/discourse/tests/unit/lib/icon-library-test.js b/app/assets/javascripts/discourse/tests/unit/lib/icon-library-test.js
index 88a3dda..b2b0a99 100644
--- a/app/assets/javascripts/discourse/tests/unit/lib/icon-library-test.js
+++ b/app/assets/javascripts/discourse/tests/unit/lib/icon-library-test.js
@@ -7,7 +7,7 @@ import { module, test } from "qunit";
 module("Unit | Utility | icon-library", function () {
   test("return icon markup", function (assert) {
-    assert.ok(iconHTML("bars").indexOf('use xlink:href="#bars"') > -1);
+    assert.ok(iconHTML("bars").indexOf('use href="#bars"') > -1);
     const nodeIcon = iconNode("bars");
     assert.strictEqual(nodeIcon.tagName, "svg");
diff --git a/app/assets/javascripts/discourse/tests/unit/lib/to-markdown-test.js b/app/assets/javascripts/discourse/tests/unit/lib/to-markdown-test.js
index 35e4cfb..aaa2765 100644
--- a/app/assets/javascripts/discourse/tests/unit/lib/to-markdown-test.js
GitHub sha: 4c46c7e334accd3679ab5634675017aa89429154
This commit appears in #15059 which was approved by tgxworld and pmusaraj. It was merged by SamSaffron.
