DEV: Removed deprecated/unneeded code from plugin.rb (#55)
  • string literals are now always frozen
  • register_svg_icon is present in all versions of discourse
  • authenticator name and title can now be defined in the locale file
  • frame_width, frame_height and message are no longer used by Discourse
diff --git a/config/locales/client.en.yml b/config/locales/client.en.yml
index d55546a..021c806 100644
--- a/config/locales/client.en.yml
+++ b/config/locales/client.en.yml
@@ -1,5 +1,9 @@
 en:
   js:
+    login:
+      patreon:
+        name: Patreon
+        title: with Patreon
     patreon:
       title: 'Patreon'
       header:
index 3a81440..72e6444 100644
--- a/plugin.rb
+++ b/plugin.rb
@@ -11,11 +11,11 @@ require 'omniauth-oauth2'
 enabled_site_setting :patreon_enabled
-PLUGIN_NAME = 'discourse-patreon'.freeze
+PLUGIN_NAME = 'discourse-patreon'
 register_asset 'stylesheets/patreon.scss'
-register_svg_icon "fab-patreon" if respond_to?(:register_svg_icon)
+register_svg_icon "fab-patreon"
 # Site setting validators must be loaded before initialize
 require_relative 'lib/validators/patreon_login_enabled_validator'
@@ -240,9 +240,4 @@ class Auth::PatreonAuthenticator < Auth::OAuth2Authenticator
-auth_provider pretty_name: 'Patreon',
-              title: 'with Patreon',
-              message: 'Authentication with Patreon (make sure pop up blockers are not enabled)',
-              frame_width: 840,
-              frame_height: 570,
-              authenticator: Auth::PatreonAuthenticator.new('patreon', trusted: true)
+auth_provider authenticator: Auth::PatreonAuthenticator.new('patreon', trusted: true)
GitHub sha: 3d7c0a28
This commit appears in #55 which was approved by eviltrout. It was merged by davidtaylorhq.
