DEV: removes DOMTokenList polyfill (#7831)
Creates more issues than it solves especially on IOS, I dont trust it anymore. Will reconsider if this is an issue in the future.
diff --git a/app/assets/javascripts/polyfills.js b/app/assets/javascripts/polyfills.js
index e39b2d5..ab97aeb 100644
--- a/app/assets/javascripts/polyfills.js
+++ b/app/assets/javascripts/polyfills.js
@@ -189,335 +189,4 @@ if (RegExp.prototype.flags === undefined) {
-// https://developer.mozilla.org/en-US/docs/Web/API/Element/classList
-// IE10/11 polyfill to fully support classList
-// 1. String.prototype.trim polyfill
-if (!"".trim)
-  String.prototype.trim = function() {
-    return this.replace(/^[\s]+|[\s]+$/g, "");
-(function(window) {
-  "use strict"; // prevent global namespace pollution
-  function checkIfValidClassListEntry(O, V) {
-    if (V === "")
-      throw new DOMException(
-        "Failed to execute '" +
-          O +
-          "' on 'DOMTokenList': The token provided must not be empty."
-    if ((wsI = V.search(wsRE)) !== -1)
-          O +
-          "' on 'DOMTokenList': " +
-          "The token provided ('" +
-          V[wsI] +
-          "') contains HTML space characters, which are not valid in tokens."
-  // 2. Implement the barebones DOMTokenList livelyness polyfill
-  if (typeof DOMTokenList !== "function")
-    (function(window) {
-      var document = window.document,
-        Object = window.Object,
-        hasOwnProp = Object.prototype.hasOwnProperty;
-      var defineProperty = Object.defineProperty,
-        allowTokenListConstruction = 0,
-        skipPropChange = 0;
-      var Element = window.Element,
-        wsI = 0,
-        wsRE = /[\11\12\14\15\40]/; // WhiteSpace Regular Expression
-      function DOMTokenList() {
-        if (!allowTokenListConstruction) throw TypeError("Illegal constructor"); // internally let it through
-      DOMTokenList.prototype.toString = DOMTokenList.prototype.toLocaleString = function() {
-        return this.value;
-      DOMTokenList.prototype.add = function() {
-        a: for (
-          var v = 0,
-            argLen = arguments.length,
-            val = "",
-            ele = this["uCL"],
-            proto = ele[" uCLp"];
-          v !== argLen;
-          ++v
-          (val = arguments[v] + ""), checkIfValidClassListEntry("add", val);
-          for (var i = 0, Len = proto.length, resStr = val; i !== Len; ++i)
-            if (this[i] === val) continue a;
-            else resStr += " " + this[i];
-          (this[Len] = val), (proto.length += 1), (proto.value = resStr);
-        (skipPropChange = 1),
-          (ele.className = proto.value),
-          (skipPropChange = 0);
-      DOMTokenList.prototype.remove = function() {
-        for (
-          var v = 0,
-            val = "",
-          v !== argLen;
-          ++v
-          (val = arguments[v] + ""), checkIfValidClassListEntry("remove", val);
-          for (
-            var i = 0, Len = proto.length, resStr = "", is = 0;
-            i !== Len;
-            ++i
-            if (is) {
-              this[i - 1] = this[i];
-            } else {
-              if (this[i] !== val) {
-                resStr += this[i] + " ";
-              } else {
-                is = 1;
-          if (!is) continue;
-          delete this[Len], (proto.length -= 1), (proto.value = resStr);
-      window.DOMTokenList = DOMTokenList;
-      function whenPropChanges() {
-        var evt = window.event,
-          prop = evt.propertyName;
-        if (
-          !skipPropChange &&
-          (prop === "className" || (prop === "classList" && !defineProperty))
-          var target = evt.srcElement,
-            protoObjProto = target[" uCLp"],
-            strval = "" + target[prop];
-          var tokens = strval.trim().split(wsRE),
-            resTokenList = target[prop === "classList" ? " uCL" : "classList"];
-          var oldLen = protoObjProto.length;
-          a: for (
-            var cI = 0, cLen = (protoObjProto.length = tokens.length), sub = 0;
-            cI !== cLen;
-            ++cI
-            for (var innerI = 0; innerI !== cI; ++innerI)
-              if (tokens[innerI] === tokens[cI]) {
-                sub++;
-                continue a;
-            resTokenList[cI - sub] = tokens[cI];
-          for (var i = cLen - sub; i < oldLen; ++i) delete resTokenList[i]; //remove trailing indexs
-          if (prop !== "classList") return;
-            (target.classList = resTokenList),
-            (target.className = strval);
-          (skipPropChange = 0), (resTokenList.length = tokens.length - sub);
-      function polyfillClassList(ele) {
-        if (!ele || !("innerHTML" in ele))
-          throw TypeError("Illegal invocation");
-        srcEle.detachEvent("onpropertychange", whenPropChanges); // prevent duplicate handler infinite loop
-        allowTokenListConstruction = 1;
-        try {
-          function protoObj() {}
-          protoObj.prototype = new DOMTokenList();
-        } finally {
-          allowTokenListConstruction = 0;
-        var protoObjProto = protoObj.prototype,
-          resTokenList = new protoObj();
-        a: for (
-          var toks = ele.className.trim().split(wsRE),
-            cI = 0,
-            cLen = toks.length,
-            sub = 0;
-          cI !== cLen;
-          ++cI
-            if (toks[innerI] === toks[cI]) {
-              sub++;
-              continue a;
-          this[cI - sub] = toks[cI];
-        (protoObjProto.length = Len - sub),
-          (protoObjProto.value = ele.className),
-          (protoObjProto[" uCL"] = ele);
-        if (defineProperty) {
-          defineProperty(ele, "classList", {
-            // IE8 & IE9 allow defineProperty on the DOM
-            enumerable: 1,
-            get: function() {
-              return resTokenList;
-            configurable: 0,
-            set: function(newVal) {
-                (ele.className = protoObjProto.value = newVal += ""),
-              var toks = newVal.trim().split(wsRE),
-                oldLen = protoObjProto.length;
-              a: for (
-                var cI = 0,
-                  cLen = (protoObjProto.length = toks.length),
-                  sub = 0;
-                cI !== cLen;
-                ++cI
-                    sub++;
-                    continue a;
-                resTokenList[cI - sub] = toks[cI];
-          defineProperty(ele, " uCLp", {
-            // for accessing the hidden prototype
-            enumerable: 0,
-            configurable: 0,
-            writeable: 0,
-            value: protoObj.prototype
-          defineProperty(protoObjProto, " uCL", {
-            enumerable: 0,
-            configurable: 0,
-            writeable: 0,
-            value: ele
-        } else {
-          (ele.classList = resTokenList),
-            (ele[" uCL"] = resTokenList),
-            (ele[" uCLp"] = protoObj.prototype);
-        srcEle.attachEvent("onpropertychange", whenPropChanges);
-      try {
-        // Much faster & cleaner version for IE8 & IE9:
GitHub sha: 7b52a110
Can you explain a bit more about the purpose of this polyfill? impact of not having it?
I added this polyfill to have full support of classlist on every browsers, especially IE.
The impact is quite low as we mostly use jquery today. Moreover add/remove work, it’s for more advanced usage like contains, replace…
I could have scoped it to IE only but I just don’t trust this polyfill, it has a lot of code and seems too big, it’s not just patching one small function as others.
