DEV: removes unused version_bump script (#13811)
diff --git a/script/version_bump.rb b/script/version_bump.rb
deleted file mode 100755
index 057cdac..0000000
--- a/script/version_bump.rb
+++ /dev/null
@@ -1,92 +0,0 @@
-#!/usr/bin/env ruby
-# frozen_string_literal: true
-# Increases the version. e.g., from 0.8.5 to 0.8.6.
-# If you want to bump the minor or major version numbers, do it manually
-# or edit lib/version.rb before running this file.
-usage = <<-END
-   Arguments:
-     <version>: The new version. Must have at least 2 parts. Examples: 0.9.8, 0.10, 0.9.7.3
-     no-commit: Don't commit the changes.
-     push:      Push the commits to github. If used by itself without the version argument,
-                it's assumed that the commit and tags are ready to be pushed.
-  Example:
-    To update the version in one step, and then push the commits in a second step:
-      ruby script/version_bump.rb 0.9.7.3
-      ruby script/version_bump.rb push
-    To do everything in one step:
-      ruby script/version_bump.rb 0.9.8 push
-  END
-VERSION_FILE_PATH = File.expand_path('../../lib/version.rb',  __FILE__)
-if ARGV.length < 1
-  puts usage
-  exit 1
-end
-new_version = ARGV[0].split('.')
-if new_version.length < (2) && !ARGV.include?('push')
-  puts "First argument must be a version number with at least 2 parts. Examples: 0.9.8, 0.10, 0.9.7.3"
-  exit 1
-end
-update_version_file = new_version.length >= 2
-if update_version_file
-  puts '', "New Version: #{new_version.join('.')}", "Updating #{VERSION_FILE_PATH}..."
-  contents = ''
-  tiny_version_bumped = false
-  File.open(VERSION_FILE_PATH) do |f|
-    contents = f.read
-    ['MAJOR', 'MINOR', 'TINY', 'PRE'].each_with_index do |name, i|
-      r = Regexp.new(name + '\s*=\s*(nil|[\d]+)')
-      m = r.match(contents)
-      v = new_version[i].to_i > 0 ? new_version[i] : (name == 'PRE' ? 'nil' : '0')
-      contents.sub!(m[0], m[0].sub(m[1], v)) if m
-    end
-  end
-  puts "Saving..."
-  File.open(VERSION_FILE_PATH, 'w+') do |f|
-    f.write(contents)
-  end
-end
-require File.expand_path('../../lib/version',  __FILE__)
-version = Discourse::VERSION::STRING
-puts "New version is: #{version}"
-unless ARGV.include?('no-commit') || !update_version_file
-  puts "Committing..."
-  `git add lib/version.rb`
-  `git commit -m "Version bump to v#{version}"`
-  sha = `git rev-parse HEAD`.strip
-  `git tag -d latest-release`
-  `git push origin :latest-release`
-  `git tag -a v#{version} -m "version #{version}" #{sha}`
-  `git tag -a latest-release -m "latest release" #{sha}`
-end
-if ARGV.include?('push')
-  puts "Pushing..."
-  `git push origin main`
-  `git push origin v#{version}`
-  `git push origin latest-release`
-end
-puts "Done", ''
GitHub sha: a10fd95a7e9843d59420220b77cae6a55ac687ae
This commit appears in #13811 which was approved by nlalonde. It was merged by nlalonde.
