DEV: Replace jquery.putCursorAtEnd (#9390)
diff --git a/app/assets/javascripts/discourse/components/composer-editor.js b/app/assets/javascripts/discourse/components/composer-editor.js
index 4ff3b96..b14b0af 100644
--- a/app/assets/javascripts/discourse/components/composer-editor.js
+++ b/app/assets/javascripts/discourse/components/composer-editor.js
@@ -30,7 +30,8 @@ import {
   clipboardData,
   safariHacksDisabled,
   caretPosition,
-  inCodeBlock
+  inCodeBlock,
+  putCursorAtEnd
 } from "discourse/lib/utilities";
 import {
   validateUploadedFiles,
@@ -123,7 +124,7 @@ export default Component.extend({
   @observes("focusTarget")
   setFocus() {
     if (this.focusTarget === "editor") {
-      $(this.element.querySelector("textarea")).putCursorAtEnd();
+      putCursorAtEnd(this.element.querySelector("textarea"));
@@ -213,7 +214,7 @@ export default Component.extend({
       !this.get("composer.canEditTitle") &&
       (!this.capabilities.isIOS || safariHacksDisabled())
-      $(this.element.querySelector(".d-editor-input")).putCursorAtEnd();
+      putCursorAtEnd(this.element.querySelector(".d-editor-input"));
     this._bindUploadTarget();
diff --git a/app/assets/javascripts/discourse/components/composer-title.js b/app/assets/javascripts/discourse/components/composer-title.js
index 9ba4f50..e036bee 100644
--- a/app/assets/javascripts/discourse/components/composer-title.js
+++ b/app/assets/javascripts/discourse/components/composer-title.js
@@ -5,9 +5,9 @@ import discourseComputed, { observes } from "discourse-common/utils/decorators";
 import { load } from "pretty-text/oneboxer";
 import { lookupCache } from "pretty-text/oneboxer-cache";
 import { ajax } from "discourse/lib/ajax";
-import afterTransition from "discourse/lib/after-transition";
 import ENV from "discourse-common/config/environment";
 import EmberObject from "@ember/object";
+import { putCursorAtEnd } from "discourse/lib/utilities";
   classNames: ["title-input"],
@@ -17,11 +17,7 @@ export default Component.extend({
   didInsertElement() {
     this._super(...arguments);
     if (this.focusTarget === "title") {
-      const $input = $(this.element.querySelector("input"));
-      afterTransition($(this.element).closest("#reply-control"), () => {
-        $input.putCursorAtEnd();
+      putCursorAtEnd(this.element.querySelector("input"));
     if (this.get("composer.titleLength") > 0) {
@@ -136,14 +132,14 @@ export default Component.extend({
           .finally(() => {
             this.set("composer.loading", false);
             schedule("afterRender", () => {
-              $(this.element.querySelector("input")).putCursorAtEnd();
       } else {
         this._updatePost(loadOnebox);
diff --git a/app/assets/javascripts/discourse/components/composer-user-selector.js b/app/assets/javascripts/discourse/components/composer-user-selector.js
index 913a935..3418697 100644
--- a/app/assets/javascripts/discourse/components/composer-user-selector.js
+++ b/app/assets/javascripts/discourse/components/composer-user-selector.js
@@ -1,6 +1,7 @@
 import { schedule } from "@ember/runloop";
 import Component from "@ember/component";
   showSelector: true,
@@ -11,7 +12,7 @@ export default Component.extend({
     if (this.focusTarget === "usernames") {
diff --git a/app/assets/javascripts/discourse/lib/utilities.js b/app/assets/javascripts/discourse/lib/utilities.js
index 03ef200..c753f4b 100644
--- a/app/assets/javascripts/discourse/lib/utilities.js
+++ b/app/assets/javascripts/discourse/lib/utilities.js
@@ -444,5 +444,11 @@ export function inCodeBlock(text, pos) {
   return result;
+export function putCursorAtEnd(element) {
+  element.focus();
+  const len = element.value.length;
+  element.setSelectionRange(len, len);
 // This prevents a mini racer crash
 export default {};
diff --git a/app/assets/javascripts/vendor.js b/app/assets/javascripts/vendor.js
index 3b36c27..adc682e 100644
--- a/app/assets/javascripts/vendor.js
+++ b/app/assets/javascripts/vendor.js
@@ -17,7 +17,6 @@
 //= require jquery.cookie.js
 //= require jquery.fileupload.js
 //= require jquery.iframe-transport.js
-//= require jquery.putcursoratend.js
 //= require jquery.tagsinput.js
 //= require jquery.sortable.js
 //= require lodash.js
diff --git a/vendor/assets/javascripts/jquery.putcursoratend.js b/vendor/assets/javascripts/jquery.putcursoratend.js
deleted file mode 100644
index d957d03..0000000
--- a/vendor/assets/javascripts/jquery.putcursoratend.js
+++ /dev/null
@@ -1,38 +0,0 @@
-// jQuery plugin: PutCursorAtEnd 1.0
-// http://plugins.jquery.com/project/PutCursorAtEnd
-// by teedyay
-// Puts the cursor at the end of a textbox/ textarea
-// codesnippet: 691e18b1-f4f9-41b4-8fe8-bc8ee51b48d4
-(function($)
-    jQuery.fn.putCursorAtEnd = function()
-    return this.each(function()
-        $(this).focus()
-        // If this function exists...
-        if (this.setSelectionRange)
-        // ... then use it
-        // (Doesn't work in IE)
-        // Double the length because Opera is inconsistent about whether a carriage return is one character or two. Sigh.
-        var len = $(this).val().length * 2;
-        this.setSelectionRange(len, len);
-        else
-        // ... otherwise replace the contents with itself
-        // (Doesn't work in Google Chrome)
-        $(this).val($(this).val());
-        // Scroll to the bottom, in case we're in a tall textarea
-        // (Necessary for Firefox and Google Chrome)
-        this.scrollTop = 999999;
-})(jQuery);
\ No newline at end of file
GitHub sha: c3593dd9
This commit appears in #9390 which was approved by eviltrout. It was merged by pmusaraj.
