DEV: Replace Overcommit with Lefthook (#7826)
Overcommit uses prebuilt hooks and require global installation. To avoid this issues replace it with Lefthook. Lefthook will be installed with npm packages. New contributors will have fully consistent git hooks.
diff --git a/.overcommit.yml b/.overcommit.yml
deleted file mode 100644
index 8a48ff5..0000000
--- a/.overcommit.yml
+++ /dev/null
@@ -1,45 +0,0 @@
-# Use this file to configure the Overcommit hooks you wish to use. This will
-# extend the default configuration defined in:
-# https://github.com/brigade/overcommit/blob/master/config/default.yml
-# At the topmost level of this YAML file is a key representing type of hook
-# being run (e.g. pre-commit, commit-msg, etc.). Within each type you can
-# customize each hook, such as whether to only run it on certain files (via
-# `include`), whether to only display output if it fails (via `quiet`), etc.
-# For a complete list of hooks, see:
-# https://github.com/brigade/overcommit/tree/master/lib/overcommit/hook
-# For a complete list of options that you can use to customize hooks, see:
-# https://github.com/brigade/overcommit#configuration
-PreCommit:
-  RuboCop:
-    enabled: true
-    command: ['bundle', 'exec', 'rubocop']
-  EsLint:
-    enabled: true
-    required_executable: './node_modules/.bin/eslint'
-    install_command: 'yarn install'
-    command: ['yarn', 'eslint', '--ext', '.es6', '-f', 'compact']
-    include: '**/*.es6'
-  YamlSyntax:
-    enabled: true
-PostCheckout:
-  BundleInstall:
-    enabled: true
-  YarnInstall:
-    enabled: true
-PostMerge:
-  BundleInstall:
-    enabled: true
-  YarnInstall:
-    enabled: true
-PostRewrite:
-  BundleInstall:
-    enabled: true
-  YarnInstall:
-    enabled: true
diff --git a/.travis.yml b/.travis.yml
index f8bc50b..16534a3 100644
--- a/.travis.yml
+++ b/.travis.yml
@@ -74,13 +74,7 @@ script:
     bash -c "
       if [ '$RUN_LINT' == '1' ]; then
-        bundle exec rubocop --parallel && \
-        yarn prettier --list-different "app/assets/stylesheets/**/*.scss" "app/assets/javascripts/**/*.es6" "test/javascripts/**/*.es6"
-        yarn eslint --ext .es6 app/assets/javascripts && \
-        yarn eslint --ext .es6 test/javascripts && \
-        yarn eslint --ext .es6 plugins/**/assets/javascripts && \
-        yarn eslint --ext .es6 plugins/**/test/javascripts && \
-        yarn eslint app/assets/javascripts test/javascripts
+        npx lefthook run lints
       else
         if [ '$QUNIT_RUN' == '1' ]; then
           bundle exec rake qunit:test['1200000'] && \
diff --git a/Gemfile b/Gemfile
index 87a682b..172970a 100644
--- a/Gemfile
+++ b/Gemfile
@@ -152,6 +152,7 @@ group :development do
   gem 'bullet', require: !!ENV['BULLET']
   gem 'better_errors'
   gem 'binding_of_caller'
+  gem 'yaml-lint'
   # waiting on 2.7.5 per: https://github.com/ctran/annotate_models/pull/595
   if rails_master?
index 18ba21d..46f9119 100644
--- a/Gemfile.lock
+++ b/Gemfile.lock
@@ -412,6 +412,7 @@ GEM
     webpush (0.3.8)
       hkdf (~> 0.2)
       jwt (~> 2.0)
+    yaml-lint (0.0.10)
 PLATFORMS
   ruby
@@ -533,6 +534,7 @@ DEPENDENCIES
   unicorn
   webmock
   webpush
+  yaml-lint
 BUNDLED WITH
    1.17.3
diff --git a/lefthook.yml b/lefthook.yml
new file mode 100644
index 0000000..d085046
--- /dev/null
+++ b/lefthook.yml
@@ -0,0 +1,49 @@
+pre-commit:
+  parallel: true
+  commands:
+    rubocop:
+      glob: '*.rb'
+      run: bundle exec rubocop {staged_files}
+    eslint:
+      glob: '*.{js,es6}'
+      run: yarn eslint --ext .es6 -f compact {staged_files}
+    yaml-syntax:
+      glob: '*.{yaml,yml}'
+      run: bundle exec yaml-lint {staged_files}
+commands: &commands
+  bundle-install:
+    files: git diff --name-only HEAD master
+    glob: '{Gemfile,Gemfile.lock,*.gemspec}'
+    run: bundle install
+  yarn-install:
+    glob: '{package.json,yarn.lock}'
+    run: yarn install
+post-checkout:
+  commands: *commands
+post-merge:
+post-rewrite:
+lints:
+  parallel: true
+  commands:
+    rubocop:
+      run: bundle exec rubocop --parallel
+    prettier:
+      run: yarn prettier --list-different app/assets/stylesheets/**/*.scss app/assets/javascripts/**/*.es6 test/javascripts/**/*.es6
+    eslint-assets:
+      run: yarn eslint --ext .es6 app/assets/javascripts
+    eslint-test:
+      run: yarn eslint --ext .es6 test/javascripts
+    eslint-plugins-assets:
+      run: yarn eslint --ext .es6 plugins/**/assets/javascripts
+    eslint-plugins-test:
+      run: yarn eslint --ext .es6 plugins/**/test/javascripts
+    eslint-assets-tests:
+      run: yarn eslint app/assets/javascripts test/javascripts
diff --git a/package.json b/package.json
index d49c13b..cf64652 100644
--- a/package.json
+++ b/package.json
@@ -33,6 +33,7 @@
     "spectrum-colorpicker": "1.8.0"
   "devDependencies": {
+    "@arkweid/lefthook": "^0.5.6",
     "babel-eslint": "^8.2",
     "chrome-launcher": "^0.10",
     "chrome-remote-interface": "^0.25",
diff --git a/yarn.lock b/yarn.lock
index 8180e84..f5a6887 100644
--- a/yarn.lock
+++ b/yarn.lock
@@ -2,6 +2,11 @@
 # yarn lockfile v1
+"@arkweid/lefthook@^0.5.6":
+  version "0.5.6"
+  resolved "https://registry.yarnpkg.com/@arkweid/lefthook/-/lefthook-0.5.6.tgz#6c44bc257c2ea2c2498c25df1757fd224a69a088"
+  integrity sha512-hnzXNq/tq7LZGOFE1CigEdSOd1lkhJpUX83pyseIQg7hzrwytnm3+qVLqnMAY/Zk/L7kvWVLXiYxJofDc+2TNg==
 "@babel/code-frame@7.0.0-beta.44":
   version "7.0.0-beta.44"
   resolved "https://registry.yarnpkg.com/@babel/code-frame/-/code-frame-7.0.0-beta.44.tgz#2a02643368de80916162be70865c97774f3adbd9"
GitHub sha: 0872a118
