DEV: Require Ember CLI to be used in development mode (#12738)
We really want to encourage all developers to use Ember CLI for local development and testing. This will display an error page if they are not with instructions on how to start the local server.
To disable it, you can set NO_EMBER_CLI=1 as an ENV variable
diff --git a/app/assets/stylesheets/ember_cli.scss b/app/assets/stylesheets/ember_cli.scss
new file mode 100644
index 0000000..175fe19
--- /dev/null
+++ b/app/assets/stylesheets/ember_cli.scss
@@ -0,0 +1,16 @@
+body.requires-ember-cli {
+  margin: 2rem;
+  font-family: Arial, Helvetica;
+  background-color: white;
+pre {
+  background-color: lightgrey;
+pre,
+code {
+  padding: 0;
+  margin: 0;
+  padding: 0.5rem;
diff --git a/app/controllers/application_controller.rb b/app/controllers/application_controller.rb
index 6903b9d..adad4c6 100644
--- a/app/controllers/application_controller.rb
+++ b/app/controllers/application_controller.rb
@@ -94,15 +94,23 @@ class ApplicationController < ActionController::Base
+  def ember_cli_required?
+    ENV['NO_EMBER_CLI'] != '1' && Rails.env.development?
+  end
+  def application_layout
+    ember_cli_required? ? "ember_cli" : "application"
+  end
   def set_layout
     case request.headers["Discourse-Render"]
     when "desktop"
-      return "application"
+      return application_layout
     when "crawler"
       return "crawler"
-    use_crawler_layout? ? 'crawler' : 'application'
+    use_crawler_layout? ? 'crawler' : application_layout
   class RenderEmpty < StandardError; end
diff --git a/app/views/layouts/ember_cli.html.erb b/app/views/layouts/ember_cli.html.erb
index 0000000..dd4e070
--- /dev/null
+++ b/app/views/layouts/ember_cli.html.erb
@@ -0,0 +1,27 @@
+<!DOCTYPE html>
+<html>
+<head>
+  <meta charset="utf-8">
+  <title><%= content_for?(:title) ? yield(:title) : SiteSetting.title %></title>
+  <%= stylesheet_link_tag(:ember_cli) %>
+</head>
+<body class="requires-ember-cli">
+  <div class='warning'>
+    <h1>Ember CLI is Required in Development Mode</h1>
+    <p>To run Ember CLI in development mode, please do the following:</p>
+    <pre><code>$ bin/ember-cli</code></pre>
+    <p>If it's your first time starting Ember CLI you'll have to run yarn:</p>
+    <pre><code>$ cd app/assets/javascripts/discourse && yarn</code></pre>
+    <p>Then visit the following URL to use Discourse:</p>
+    <a href="http://localhost:4200/">http://localhost:4200</a>
+  </div>
+</body>
+</html>
diff --git a/bin/ember-cli b/bin/ember-cli
index 1a3da32..21ac6b8 100755
--- a/bin/ember-cli
+++ b/bin/ember-cli
@@ -4,7 +4,7 @@
 require 'pathname'
 RAILS_ROOT = File.expand_path("../../", Pathname.new(__FILE__).realpath)
-PORT = ENV["UNICORN_PORT"] ||= "9292"
+PORT = ENV["UNICORN_PORT"] ||= "3000"
 Dir.chdir(RAILS_ROOT) # rubocop:disable Discourse/NoChdir
 Dir.chdir("app/assets/javascripts/discourse") # rubocop:disable Discourse/NoChdir
diff --git a/spec/components/stylesheet/compiler_spec.rb b/spec/components/stylesheet/compiler_spec.rb
index b71b2d6..4e91d10 100644
--- a/spec/components/stylesheet/compiler_spec.rb
+++ b/spec/components/stylesheet/compiler_spec.rb
@@ -6,6 +6,8 @@ require 'stylesheet/compiler'
 describe Stylesheet::Compiler do
   describe 'compilation' do
     Dir["#{Rails.root.join("app/assets/stylesheets")}/*.scss"].each do |path|
+      next if path =~ /ember_cli/
       path = File.basename(path, '.scss')
       it "can compile '#{path}' css" do
GitHub sha: 51f872f1
This commit appears in #12738 which was approved by CvX. It was merged by eviltrout.
