DEV: Restore skipped JS test
This works for me locally, so the issue has likely been fixed since the test was skipped
diff --git a/test/javascripts/acceptance/preferences-test.js.es6 b/test/javascripts/acceptance/preferences-test.js.es6
index 2f67c8b..58360b9 100644
--- a/test/javascripts/acceptance/preferences-test.js.es6
+++ b/test/javascripts/acceptance/preferences-test.js.es6
@@ -91,10 +91,9 @@ QUnit.test("update some fields", async assert => {
     "tags tab isn't there when tags are disabled"
-  // Error: Unhandled request in test environment: /themes/assets/10d71596-7e4e-4dc0-b368-faa3b6f1ce6d?_=1493833562388 (GET)
-  // click(".preferences-nav .nav-interface a");
-  // click('.control-group.other input[type=checkbox]:first');
-  // savePreferences();
+  click(".preferences-nav .nav-interface a");
+  click(".control-group.other input[type=checkbox]:first");
+  savePreferences();
   assert.ok(
     !exists(".preferences-nav .nav-apps a"),
GitHub sha: 337545f4
