DEV: Restore UploadRecovery specs (#10543)
Originally disabled in 0c0192e. Upload specs now use separate paths for each spec worker.
Fixes an issue in UploadRecovery#recover_from_local – it didn’t take into account the testing infix (e.g. test_0) in the uploads/tombstone paths.
diff --git a/lib/upload_recovery.rb b/lib/upload_recovery.rb
index 7ea190c..221e1d3 100644
--- a/lib/upload_recovery.rb
+++ b/lib/upload_recovery.rb
@@ -95,21 +95,14 @@ class UploadRecovery
   def recover_from_local(sha1:, user_id:)
-    public_path = Rails.root.join("public")
     @paths ||= begin
       Dir.glob(File.join(
-        public_path,
-        'uploads',
-        'tombstone',
-        RailsMultisite::ConnectionManagement.current_db,
+        Discourse.store.tombstone_dir,
         'original',
       )).concat(Dir.glob(File.join(
-        public_path,
-        'uploads',
+        Discourse.store.upload_path,
         'original',
diff --git a/spec/lib/upload_recovery_spec.rb b/spec/lib/upload_recovery_spec.rb
index 3d8b840..9a18a34 100644
--- a/spec/lib/upload_recovery_spec.rb
+++ b/spec/lib/upload_recovery_spec.rb
@@ -49,7 +49,7 @@ RSpec.describe UploadRecovery do
   describe '#recover' do
     describe 'when given an invalid sha1' do
-      xit 'should not do anything' do
+      it 'does nothing' do
         upload_recovery.expects(:recover_from_local).never
         post.update!(
@@ -66,7 +66,7 @@ RSpec.describe UploadRecovery do
-    xit 'accepts a custom ActiveRecord relation' do
+    it 'accepts a custom ActiveRecord relation' do
       post.update!(updated_at: 2.days.ago)
       upload.destroy!
@@ -85,7 +85,7 @@ RSpec.describe UploadRecovery do
         ).tap(&:link_post_uploads)
-      xit 'should recover the attachment' do
+      it 'recovers the attachment' do
         expect do
           upload2.destroy!
         end.to change { post.reload.uploads.count }.from(1).to(0)
@@ -99,7 +99,7 @@ RSpec.describe UploadRecovery do
-    xit 'should recover uploads and attachments' do
+    it 'recovers uploads and attachments' do
       stub_request(:get, "http://test.localhost#{upload.url}")
         .to_return(status: 200)
@@ -125,7 +125,7 @@ RSpec.describe UploadRecovery do
-      xit 'should recover the upload' do
+      it 'recovers the upload' do
@@ -152,7 +152,7 @@ RSpec.describe UploadRecovery do
@@ -179,7 +179,7 @@ RSpec.describe UploadRecovery do
GitHub sha: 188d2243
This commit appears in #10543 which was approved by eviltrout. It was merged by CvX.
