DEV: revert bundler to 1.7.3
At the moment bundler 2.0 is not compatible with:
https://github.com/discourse/discourse-backup-uploads-to-s3
We plan to get this fixed but in the mean time do not upgrade.
followup to 2a7065c5
index fbc5593..b625d8d 100644
--- a/Gemfile.lock
+++ b/Gemfile.lock
@@ -533,4 +533,4 @@ DEPENDENCIES
   webpush
 BUNDLED WITH
-   2.0.1
+   1.17.3
GitHub sha: a4627c3d
is 2.0 fine if one doesnt use the backup plugin? or would it be safer to downgrade the rpm also to 1.17?
I am unsure how to answer this cause we simply did not test this, very hard to tell what other side effects will pop up.
