DEV: run db:create and db:migrate on turbo specs
This ensures multisite specs run correctly when running ./bin/turbo_rspec
diff --git a/lib/tasks/docker.rake b/lib/tasks/docker.rake
index 364bafb..18007c9 100644
--- a/lib/tasks/docker.rake
+++ b/lib/tasks/docker.rake
@@ -112,14 +112,11 @@ task 'docker:test' do
# for js tests
ENV["SKIP_MULTISITE"] = "1" if ENV["JS_ONLY"]
- db_rake_task_prefix =
- if ENV['USE_TURBO']
- 'parallel'
- else
- 'db'
- end
+ @good &&= run_or_fail("bundle exec rake db:create")
- @good &&= run_or_fail("bundle exec rake #{db_rake_task_prefix}:create")
+ if ENV['USE_TURBO']
+ @good &&= run_or_fail("bundle exec rake parallel:create")
+ end
if ENV["INSTALL_OFFICIAL_PLUGINS"]
@good &&= run_or_fail("bundle exec rake plugin:install_all_official")
@@ -136,7 +133,11 @@ task 'docker:test' do
"LOAD_PLUGINS=1 "
- @good &&= run_or_fail("#{command_prefix}bundle exec rake #{db_rake_task_prefix}:migrate")
+ @good &&= run_or_fail("#{command_prefix}bundle exec rake db:migrate")
+ @good &&= run_or_fail("bundle exec rake parallel:migrate")
+ end
puts "travis_fold:end:prepare_tests" if ENV["TRAVIS"]
GitHub sha: befcf67c
