DEV: security restriction in dev mode broke tests
diff --git a/spec/rails_helper.rb b/spec/rails_helper.rb
index 3eb1fb2..c5dcc9b 100644
--- a/spec/rails_helper.rb
+++ b/spec/rails_helper.rb
@@ -78,6 +78,10 @@ SiteSetting.automatically_download_gravatars = false
 SeedFu.seed
+# we need this env var to ensure that we can impersonate in test
+# this enable integration_helpers sign_in helper
+ENV['DISCOURSE_DEV_ALLOW_ANON_TO_IMPERSONATE'] = '1'
 module TestSetup
   # This is run before each test and before each before_all block
   def self.test_setup(x = nil)
GitHub sha: 984516fd
