DEV: Skip CSS watcher when running QUnit tests and expose more Chrome logs (PR #13390)
There are 2 changes in this PR:
  1. Add a new environment variable called DISCOURSE_SKIP_CSS_WATCHER to disable our stylesheet watcher, and make the qunit:test rake task set this variable on the Unicorn/Rails server it spins up to disable our stylesheet watcher when running the tests because it doesn’t really need it.
  2. Print more Chrome logs (such as network/security errors) to the console.
GitHub
