DEV: Skip I18n in plugins until they can be updated
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 25dbc38..b5a33d7 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -137,7 +137,7 @@ jobs:
         if: env.BUILD_TYPE == 'LINT'
         run: |
           yarn eslint app/assets/javascripts test/javascripts
-          yarn eslint --ext .es6 app/assets/javascripts test/javascripts plugins
+          yarn eslint --global I18n --ext .es6 plugins
       - name: Prettier
diff --git a/lib/tasks/docker.rake b/lib/tasks/docker.rake
index 2d1f9fe..6733ae3 100644
--- a/lib/tasks/docker.rake
+++ b/lib/tasks/docker.rake
@@ -66,7 +66,7 @@ task 'docker:test' do
       if ENV["SINGLE_PLUGIN"]
         @good &&= run_or_fail("bundle exec rubocop --parallel plugins/#{ENV["SINGLE_PLUGIN"]}")
-        @good &&= run_or_fail("yarn eslint --ext .es6 plugins/#{ENV['SINGLE_PLUGIN']}")
+        @good &&= run_or_fail("yarn eslint --global I18n --ext .es6 plugins/#{ENV['SINGLE_PLUGIN']}")
         puts "Listing prettier offenses in #{ENV['SINGLE_PLUGIN']}:"
         @good &&= run_or_fail_prettier("plugins/#{ENV['SINGLE_PLUGIN']}/**/*.scss", "plugins/#{ENV['SINGLE_PLUGIN']}/**/*.es6")
@@ -74,7 +74,9 @@ task 'docker:test' do
         @good &&= run_or_fail("bundle exec rake plugin:update_all") unless ENV["SKIP_PLUGINS"]
         @good &&= run_or_fail("bundle exec rubocop --parallel") unless ENV["SKIP_CORE"]
         @good &&= run_or_fail("yarn eslint app/assets/javascripts test/javascripts") unless ENV["SKIP_CORE"]
-        @good &&= run_or_fail("yarn eslint --ext .es6 app/assets/javascripts test/javascripts plugins") unless ENV["SKIP_PLUGINS"]
+        # TODO: remove --global I18n once plugins can be updated
+        @good &&= run_or_fail("yarn eslint --global I18n --ext .es6 plugins") unless ENV["SKIP_PLUGINS"]
           puts "Listing prettier offenses in core:"
GitHub sha: 42b300b9
