DEV: Skip logging in test environment (#14971)
It adds unnecessary noise when running the test suite.
diff --git a/lib/s3_cors_rulesets.rb b/lib/s3_cors_rulesets.rb
index 7178e1a..788c6f6 100644
--- a/lib/s3_cors_rulesets.rb
+++ b/lib/s3_cors_rulesets.rb
@@ -49,19 +49,25 @@ class S3CorsRulesets
     s3_helper = S3Helper.build_from_config(
       s3_client: s3_client, use_db_s3_config: use_db_s3_config
-    puts "Attempting to apply ASSETS S3 CORS ruleset in bucket #{s3_helper.s3_bucket_name}."
+    if !Rails.env.test?
+      puts "Attempting to apply ASSETS S3 CORS ruleset in bucket #{s3_helper.s3_bucket_name}."
+    end
     assets_rules_status = s3_helper.ensure_cors!([S3CorsRulesets::ASSETS]) ? RULE_STATUS_APPLIED : RULE_STATUS_EXISTED
     if SiteSetting.enable_backups? && SiteSetting.backup_location == BackupLocationSiteSetting::S3
       backup_s3_helper = S3Helper.build_from_config(
         s3_client: s3_client, use_db_s3_config: use_db_s3_config, for_backup: true
-      puts "Attempting to apply BACKUP_DIRECT_UPLOAD S3 CORS ruleset in bucket #{backup_s3_helper.s3_bucket_name}."
+        puts "Attempting to apply BACKUP_DIRECT_UPLOAD S3 CORS ruleset in bucket #{backup_s3_helper.s3_bucket_name}."
+      end
       backup_rules_status = backup_s3_helper.ensure_cors!([S3CorsRulesets::BACKUP_DIRECT_UPLOAD]) ? RULE_STATUS_APPLIED : RULE_STATUS_EXISTED
     if SiteSetting.enable_direct_s3_uploads
-      puts "Attempting to apply DIRECT_UPLOAD S3 CORS ruleset in bucket #{s3_helper.s3_bucket_name}."
+        puts "Attempting to apply DIRECT_UPLOAD S3 CORS ruleset in bucket #{s3_helper.s3_bucket_name}."
+      end
       direct_upload_rules_status = s3_helper.ensure_cors!([S3CorsRulesets::DIRECT_UPLOAD]) ? RULE_STATUS_APPLIED : RULE_STATUS_EXISTED
GitHub sha: 8f5412cccf8d775467943429c7524881c6daa546
This commit appears in #14971 which was approved by CvX. It was merged by OsamaSayegh.
