DEV: Spec shouldn't depend on translation
DEV: Spec shouldn’t depend on translation
diff --git a/spec/services/push_notification_pusher_spec.rb b/spec/services/push_notification_pusher_spec.rb
index 62ae1cf..851675c 100644
--- a/spec/services/push_notification_pusher_spec.rb
+++ b/spec/services/push_notification_pusher_spec.rb
@@ -47,8 +47,10 @@ RSpec.describe PushNotificationPusher do
       SiteSetting.allow_user_locale = true
       user.update!(locale: 'pt_BR')
+      TranslationOverride.upsert!("pt_BR", "discourse_push_notifications.popup.mentioned", "pt_BR notification")
       Webpush.expects(:payload_send).with do |*args|
-        args.to_s.include?("system mencionou")
+        JSON.parse(args.first[:message])["title"] == "pt_BR notification"
       end.once
       create_subscription
GitHub sha: 0ea58fe51fe7bdfdc573d01e393592b73ffb49b8
This commit appears in #13797 which was approved by CvX. It was merged by tgxworld.
