DEV: Split max decompressed setting for themes and backups (#8179)
diff --git a/config/site_settings.yml b/config/site_settings.yml
index 2d5daec..2f3962e 100644
--- a/config/site_settings.yml
+++ b/config/site_settings.yml
@@ -1201,9 +1201,12 @@ files:
     default: 5
     min: 0
     max: 20
-  decompressed_file_max_size_mb:
+  decompressed_theme_max_file_size_mb:
     default: 1000
     hidden: true
+  decompressed_backup_max_file_size_mb:
+    default: 100000
+    hidden: true
 trust:
   default_trust_level:
diff --git a/db/migrate/20191011131041_migrate_decompressed_file_max_size_mb.rb b/db/migrate/20191011131041_migrate_decompressed_file_max_size_mb.rb
new file mode 100644
index 0000000..f3db85d
--- /dev/null
+++ b/db/migrate/20191011131041_migrate_decompressed_file_max_size_mb.rb
@@ -0,0 +1,19 @@
+class MigrateDecompressedFileMaxSizeMb < ActiveRecord::Migration[6.0]
+  def up
+    current_value = DB.query_single("SELECT value FROM site_settings WHERE name ='decompressed_file_max_size_mb' ").first
+    if current_value && current_value != '1000'
+      DB.exec <<~SQL
+        INSERT INTO site_settings (name, data_type, value, created_at, updated_at)
+        VALUES
+          ('decompressed_theme_max_file_size_mb', 3, #{current_value}, current_timestamp, current_timestamp),
+          ('decompressed_backup_max_file_size_mb', 3, #{current_value}, current_timestamp, current_timestamp)
+      SQL
+    end
+  end
+  def down
+  end
+end
diff --git a/lib/backup_restore/restorer.rb b/lib/backup_restore/restorer.rb
index 2480941..42fd2db 100644
--- a/lib/backup_restore/restorer.rb
+++ b/lib/backup_restore/restorer.rb
@@ -92,6 +92,9 @@ module BackupRestore
       extract_uploads
       after_restore_hook
+    rescue Compression::Strategy::ExtractFailed
+      log "The uncompressed file is too big. Consider increasing the decompressed_theme_max_file_size_mb hidden setting."
+      rollback
     rescue SystemExit
       log "Restore process was cancelled!"
       rollback
@@ -138,7 +141,7 @@ module BackupRestore
       pipeline = Compression::Pipeline.new([Compression::Tar.new, Compression::Gzip.new])
-      unzipped_path = pipeline.decompress(@tmp_directory, @archive_filename)
+      unzipped_path = pipeline.decompress(@tmp_directory, @archive_filename, available_size)
       pipeline.strip_directory(unzipped_path, @tmp_directory)
@@ -170,11 +173,15 @@ module BackupRestore
       log "Extracting dump file..."
-      Compression::Gzip.new.decompress(@tmp_directory, @dump_filename)
+      Compression::Gzip.new.decompress(@tmp_directory, @dump_filename, available_size)
     protected
+    def available_size
+      SiteSetting.decompressed_backup_max_file_size_mb
+    end
     def ensure_restore_is_enabled
       raise BackupRestore::RestoreDisabledError unless Rails.env.development? || SiteSetting.allow_restore?
diff --git a/lib/compression/pipeline.rb b/lib/compression/pipeline.rb
index f955268..98a93cc 100644
--- a/lib/compression/pipeline.rb
+++ b/lib/compression/pipeline.rb
@@ -20,10 +20,10 @@ module Compression
-    def decompress(dest_path, compressed_file_path, allow_non_root_folder: false)
+    def decompress(dest_path, compressed_file_path, max_size, allow_non_root_folder: false)
       @strategies.reverse.reduce(compressed_file_path) do |to_decompress, strategy|
         last_extension = strategy.extension
-        strategy.decompress(dest_path, to_decompress, allow_non_root_folder: allow_non_root_folder)
+        strategy.decompress(dest_path, to_decompress, max_size, allow_non_root_folder: allow_non_root_folder)
         to_decompress.gsub(last_extension, '')
diff --git a/lib/compression/strategy.rb b/lib/compression/strategy.rb
index 921ebd8..47151a3 100644
--- a/lib/compression/strategy.rb
+++ b/lib/compression/strategy.rb
@@ -9,11 +9,11 @@ module Compression
       file_name.include?(extension)
       sanitized_compressed_file_path = sanitize_path(compressed_file_path)
       get_compressed_file_stream(sanitized_compressed_file_path) do |compressed_file|
-        available_size = calculate_available_size
+        available_size = calculate_available_size(max_size)
         entries_of(compressed_file).each do |entry|
           entry_path = build_entry_path(
@@ -59,8 +59,8 @@ module Compression
-    def calculate_available_size
-      1024**2 * (SiteSetting.decompressed_file_max_size_mb / 1.049) # Mb to Mib
+    def calculate_available_size(max_size)
+      1024**2 * (max_size / 1.049) # Mb to Mib
     def entries_of(compressed_file)
diff --git a/lib/theme_store/zip_importer.rb b/lib/theme_store/zip_importer.rb
index c1a4aea..d252037 100644
--- a/lib/theme_store/zip_importer.rb
+++ b/lib/theme_store/zip_importer.rb
@@ -18,8 +18,9 @@ class ThemeStore::ZipImporter
     FileUtils.mkdir(@temp_folder)
     Dir.chdir(@temp_folder) do
+      available_size = SiteSetting.decompressed_theme_max_file_size_mb
       Compression::Engine.engine_for(@original_filename).tap do |engine|
-        engine.decompress(@temp_folder, @filename)
+        engine.decompress(@temp_folder, @filename, available_size)
         engine.strip_directory(@temp_folder, @temp_folder, relative: true)
diff --git a/spec/components/theme_store/zip_exporter_spec.rb b/spec/components/theme_store/zip_exporter_spec.rb
index e7df513..922ae30 100644
--- a/spec/components/theme_store/zip_exporter_spec.rb
+++ b/spec/components/theme_store/zip_exporter_spec.rb
@@ -63,7 +63,8 @@ describe ThemeStore::ZipExporter do
     file = 'discourse-header-icons.zip'
     dest = 'discourse-header-icons'
     Dir.chdir(dir) do
-      Compression::Zip.new.decompress(dir, file, allow_non_root_folder: true)
+      Compression::Zip.new.decompress(dir, file, available_size, allow_non_root_folder: true)
       `rm #{file}`
       folders = Dir.glob("**/*").reject { |f| File.file?(f) }
diff --git a/spec/lib/compression/engine_spec.rb b/spec/lib/compression/engine_spec.rb
index 04b6f7d..27a1619 100644
--- a/spec/lib/compression/engine_spec.rb
+++ b/spec/lib/compression/engine_spec.rb
@@ -3,6 +3,8 @@
 require 'rails_helper'
 describe Compression::Engine do
+  let(:available_size) { SiteSetting.decompressed_theme_max_file_size_mb }
   before do
     @temp_folder = "#{Pathname.new(Dir.tmpdir).realpath}/#{SecureRandom.hex}"
     @folder_name = 'test'
@@ -36,7 +38,7 @@ describe Compression::Engine do
       it 'decompress the folder and inspect files correctly' do
         engine = described_class.engine_for(@compressed_path)
-        engine.decompress(@temp_folder, "#{@temp_folder}/#{@folder_name}.zip")
+        engine.decompress(@temp_folder, "#{@temp_folder}/#{@folder_name}.zip", available_size)
         expect(read_file("test/hello.txt")).to eq("hello world")
         expect(read_file("test/a/inner")).to eq("hello world inner")
@@ -49,7 +51,7 @@ describe Compression::Engine do
-        engine.decompress(@temp_folder, "#{@temp_folder}/#{@folder_name}.tar.gz")
+        engine.decompress(@temp_folder, "#{@temp_folder}/#{@folder_name}.tar.gz", available_size)
@@ -62,7 +64,7 @@ describe Compression::Engine do
-        engine.decompress(@temp_folder, "#{@temp_folder}/#{@folder_name}.tar")
+        engine.decompress(@temp_folder, "#{@temp_folder}/#{@folder_name}.tar", available_size)
GitHub sha: 01bc465d
