DEV: support --fail-fast in bin/turbo_rspec (#8170)
  • [WIP] - default turbo spec env to test
  • FEATURE: support for --fast-fail in bin/turbo_rspec
  • fast-fail -> fail_fast to match rspec
  • Moved thread killing outside of fail-fast check
  • Removed failure_count incrementation from fast_fail_met
diff --git a/bin/turbo_rspec b/bin/turbo_rspec
index 035fae7..66464bc 100755
--- a/bin/turbo_rspec
+++ b/bin/turbo_rspec
@@ -1,12 +1,15 @@
 #!/usr/bin/env ruby
 # frozen_string_literal: true
+ENV['RAILS_ENV'] ||= 'test'
 require './lib/turbo_tests'
 require 'optparse'
 requires = []
 formatters = []
 verbose = false
+fail_fast = nil
 OptionParser.new do |opts|
   opts.on("-r", "--require PATH", "Require a file.") do |filename|
@@ -33,6 +36,12 @@ OptionParser.new do |opts|
   opts.on("-v", "--verbose", "More output") do
     verbose = true
+  opts.on("--fail-fast=[N]") do |n|
+    n = Integer(n) rescue nil
+    fail_fast = (n.nil? || n < 1) ? 1 : n
+  end
 end.parse!(ARGV)
 requires.each { |f| require(f) }
@@ -54,7 +63,8 @@ success =
   TurboTests::Runner.run(
     formatters: formatters,
     files: ARGV.empty? ? ["spec"] : ARGV,
-    verbose: verbose
+    verbose: verbose,
+    fail_fast: fail_fast
 if success
diff --git a/lib/turbo_tests/runner.rb b/lib/turbo_tests/runner.rb
index a8c0919..0e015bf 100644
--- a/lib/turbo_tests/runner.rb
+++ b/lib/turbo_tests/runner.rb
@@ -7,6 +7,7 @@ module TurboTests
       formatters = opts[:formatters]
       start_time = opts.fetch(:start_time) { Time.now }
       verbose = opts.fetch(:verbose, false)
+      fail_fast = opts.fetch(:fail_fast, nil)
       if verbose
         STDERR.puts "VERBOSE"
@@ -17,7 +18,8 @@ module TurboTests
       new(
         reporter: reporter,
         files: files,
-        verbose: verbose
+        verbose: verbose,
       ).run
@@ -25,6 +27,8 @@ module TurboTests
       @reporter = opts[:reporter]
       @files = opts[:files]
       @verbose = opts[:verbose]
+      @fail_fast = opts[:fail_fast]
+      @failure_count = 0
       @messages = Queue.new
       @threads = []
@@ -215,6 +219,11 @@ module TurboTests
           when 'example_failed'
             example = FakeExample.from_obj(message[:example])
             @reporter.example_failed(example)
+            @failure_count += 1
+            if fail_fast_met
+              @threads.each(&:kill)
+              break
+            end
           when 'seed'
           when 'close'
           when 'exit'
@@ -231,5 +240,9 @@ module TurboTests
       rescue Interrupt
+    def fail_fast_met
+      !@fail_fast.nil? && @fail_fast >= @failure_count
+    end
GitHub sha: 9b4aba0d
